Door Panel Removal
Old May 6, 2008 | 01:38 PM
tonyd414's Avatar
tonyd414
Default Door Panel Removal
Guys - I am looking for DIY info on how to remove the door panel so I can install a new Bose speaker. I did some searches and got no hits.
Old May 6, 2008 | 01:40 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Tony -
http://www.vetteessentials.com/instr...or_handle.html
best regards -
mqqn
Old May 6, 2008 | 01:51 PM
MagRedConv's Avatar
MagRedConv
Check out the sticky in the audio section
Old May 6, 2008 | 03:04 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Very simple cliff notes.
Roll the windows down.
Remove access panel from behind the door pull.
Remove the torx screws.
Remove the reflector.
Pull from the reflector hole with both hands.
Watch out for the wires.
Old May 6, 2008 | 06:47 PM
Bakersfield's Avatar
Bakersfield
This might help.
http://forums.corvetteforum.com/show....php?t=1606865
Old May 6, 2008 | 09:52 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Originally Posted by mqqn
All you need is right here.
Old May 6, 2008 | 10:04 PM
motogib1's Avatar
motogib1
I remove my door panel a couple years ago using tech tips from : his methodology worked well and has good pictures for reference.
Old May 7, 2008 | 07:41 AM
tonyd414's Avatar
tonyd414
This is perfect - thanks guys!!
To Door Panel Removal
