New steering wheel shimmy
Old May 7, 2008 | 11:38 AM
Vintv1's Avatar
Vintv1
5th Gear
Default New steering wheel shimmy
My '00 Bowling Green Roadster has always run straight and true since I've owned it. I had the crankcase and AC pullies replaced. The steering rack was removed to get to the crank pulley. Once repaired, the car now has a bad shimmy. I've had it checked, and everything seems back in place and tight. I've had the 4 tires balanced again on a machine. And a 4 wheel alignment was done. ( it was out). Still I've got a front end shimmy through the steering wheel at any speed over 45mph. The tires have about 22,000 miles on RFT Firestones. The balance tech at Firestone said one tire had a slight flat spot and he spun the tire on the rim before rebalancing. Still the shimmy!
Should I have the tires balanced on the car? I really miss the awesome smooth straight ride my baby had!
Old May 8, 2008 | 12:08 AM
roll4speed's Avatar
roll4speed
Vince,
I hope it's just the tires and not that the mechanic messed it up. Good luck.
Roll4Speed
