Brake fluid question
Old Apr 6, 2008 | 11:05 AM
rehirsch8's Avatar
rehirsch8
Default Brake fluid question
I want to change out my brake fluid this sprint and I was looking at the Amsoil web site. They recommend their DOT 4 fluid for a C5. The cap says to use DOT 3 fluid. Is there any issue using DOT4? Thanks!!
Old Apr 6, 2008 | 12:35 PM
AU N EGL's Avatar
AU N EGL
DOT 4 is a far better brake fluid. Higher Dry and Wet boiling points. Go with the DOT4
DOT3 or originally designed for drum brakes, It works but DOT 4 is better
Old Apr 6, 2008 | 12:47 PM
BlackZ06's Avatar
BlackZ06
DOT4 from any reputable fluid supplier (such as Castrol) works GREAT !!
Old Apr 6, 2008 | 01:23 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I'm going to shift to the new AMSOIL DOT 4 fluid this year in my Z06.
AMSOIL Series 500 High Performance DOT 3 Brake Fluid
AMSOIL Series 600 DOT 4 Racing Brake Fluid
DOT 3
Dry 525F, Wet 313F
DOT 4
Dry 580F, Wet 410F
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old May 4, 2008 | 03:58 PM
ShadowLight's Avatar
ShadowLight
DOT 3
Dry 525F, Wet 313F
DOT 4
Dry 580F, Wet 410F
How has that been working out for ya? Using it in your clutch as well?
Old May 6, 2008 | 01:23 AM
C66 Racing's Avatar
C66 Racing
Um... I'd like to say that I've had a chance to take my car to the track... but I can't. Been getting ready for deployment and been too busy. Racing season for me postponed to the fall after a summer deployment.
FYI, I will, but haven't yet, use the DOT 4 version in my clutch as well as the brakes. Since I bought my Z06 new in Aug 2001, I've been using my brake fluid of choice in my clutch without issues. Used Motul RBF 600 for a few years, then switched to Wilwood EXP 600 Plus for a few years.
Old May 7, 2008 | 08:48 AM
ShadowLight
I think I'm probably going to get some and give it a whirl. I had clutch issues in Colorado (just moved to Texas) which is inherently slower and therefore less heat, I can only imagine down here...so I better do all I can.
Old May 8, 2008 | 12:12 AM
C66 Racing's Avatar
C66 Racing
Dropping you a PM with info on the AMSOIL Preferred Customer Program.
To Brake fluid question
