how does traction control work???
Old May 7, 2008 | 08:38 AM
RON NARDONE's Avatar
RON NARDONE
Default how does traction control work???
how does traction control work???? it seems complicated to throttle down the engine in spurts so whats going on in that motor to limit slip????
Old May 7, 2008 | 08:48 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Timing retarding, along with throttle etc.
Old May 7, 2008 | 08:59 AM
BlackZ06's Avatar
BlackZ06
From the Service Manual .......
Traction Control System (NW9)
When drive wheel slip is noted when the brake is not applied, the EBCM will enter traction control mode.
First the EBCM requests the PCM to reduce the amount of torque to the drive wheels via the requested torque signal circuit. The PCM reduces torque to the drive wheels by retarding spark timing and turning off fuel injectors. The PCM reports the amount of torque delivered to the drive wheels via the delivered torque signal circuit.
If the engine torque reduction does not eliminate drive wheel slip the EBCM will actively apply the drive wheel brakes. During traction control braking, hydraulic pressure in each drive wheel circuit is controlled to prevent each drive wheel from slipping. The master cylinder isolation valve closes in order to isolate the master cylinder from the rest of the hydraulic system. The prime valve then opens in order to allow the pump to accumulate brake fluid in order to build hydraulic pressure for braking. The drive wheel inlet and outlet solenoid valves then open and close in order to perform the following functions
* Pressure hold
* Pressure increase
* Pressure decrease
so sayeth the manual ......
Old May 7, 2008 | 09:09 AM
RON NARDONE
it "is" complicated what happened to good old pumping the brakes
Old May 7, 2008 | 10:06 AM
MagneticRed1977's Avatar
MagneticRed1977
* Pressure hold
* Pressure increase
* Pressure decrease
Praise the "Manual" can I have a "Amen"
Old May 7, 2008 | 12:18 PM
BlackZ06's Avatar
BlackZ06
Amen .....
Old May 7, 2008 | 12:28 PM
BlackZ06's Avatar
BlackZ06
"Pumping" the brakes is usually a function of the Anti-Lock Brake System (ABS) ..... which is a completely different function than the others the EBCM performs ...
Traction Control communicates with the engine as part of its function (and controls rear braking only) .... Active Handling can use a single brake caliper in the performance of its function (which you can't do stepping on the brake pedal) ... and other functions such as DRP (Dynamic Rear Proprtioning) and RSC (Rear Stability Control) also are functions that control portions of the brake system as compared to your limited control of either all calipers, or none, from the brake pedal.
Old May 7, 2008 | 01:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can play in " OFF " mode! It completely shuts off Active Handling and Traction Control,,,,But,,,, if you think that your better than the computer be my guess to use it.
There are time when driving with the system in the OFF mode is appreciate but, for the majority of people on the highway, they shouldn't do that!
If your car is equipped with Active handling COMPETITION Mode is very cool!
I don't think that you can shut off the anti lock brakes unless you disable the EBTCM.
BC
Old May 7, 2008 | 02:40 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Driving without TC on can bite you in the butt really quick.
360's are not out of the question.
Old May 7, 2008 | 03:40 PM
Bluefire's Avatar
Bluefire
With TC off the, azz end of the car frequently tries to pass you on the right.
Old May 7, 2008 | 06:03 PM
DOUG @ ECS's Avatar
DOUG @ ECS
BC
You are correct on the ABS staying on Bill.
I personally shut everything off when I'm on the road course, it has improved my lap times substantially, but for street use, I'm with you. Leave it on or in comp mode.
Old May 7, 2008 | 06:52 PM
hawk4077's Avatar
hawk4077
Ok now we've started it what dose comp mode do that's different
Old May 7, 2008 | 08:55 PM
VinnyT's Avatar
VinnyT
Not all of us have Competition mode....
<sigh>
Old May 7, 2008 | 09:12 PM
jss812's Avatar
jss812
AH remains on, TC is off. In my car, just hold down the AH button for something like 5 seconds and the DIC will display something like Traction Control Disengaged.
Old May 7, 2008 | 10:59 PM
tiojames's Avatar
tiojames
Yes, it certainly has tried to.
Old May 8, 2008 | 12:31 AM
jornahow's Avatar
jornahow
Don't forget that (especially with an automatic) there is torque management even when traction control is not engaged. It alters timing and fuel to lower torque with gear changes to reduce stress on the drivetrain.
To how does traction control work???
