Abs/active Hdlg Service Msg
Old May 7, 2008 | 01:16 PM
borkg2006's Avatar
borkg2006
Default Abs/active Hdlg Service Msg
This morning, for no apparent reason, I got an SERVICE ABS, SERVICE ACTIVE HANDLING message on my dash accompanied by those 2 icons lighting up on the dash. I got home, checked my manual and it says to shut the car off and restart it and it'll probably go away, which it did. Then, on my next trip out, my HUD, suddenly has everything lit up, I mean every icon on it was blazing. I turned the HUD off while still driving and when it turned off, it looked like a curtain was gradually being pulled from right to left over the display. I waited about 5 min and turned it on again. At first it was OK but eventually went into overload mode again. I again turned the HUD off and again, it looked like a curtain was being pulled over it only this time from top to bottom. Again waited a bit and turned it on again and again it eventually went into overload. I stopped, turned off the car and everything appears to be normal on re-start.
Any ideas what gremlin is causing this?
Old May 7, 2008 | 01:23 PM
BlackZ06's Avatar
BlackZ06
OK ...... I'm biting my tongue .... how many THOUSANDS of posts on the forum have to refer to this "problem" ..........
DUMP the DTC data ...
https://www.corvetteforum.com/techti...D=26&TopicID=1
post here .... someone will help you ......
Old May 7, 2008 | 02:48 PM
borkg2006's Avatar
borkg2006
Thanks - I knew I had seen this here before but couldn't find it via search. You've been a great help.
To Abs/active Hdlg Service Msg
