Timing Chain Question
Old May 8, 2008 | 01:35 PM
EStreeter's Avatar
EStreeter
Default Timing Chain Question
I have noticed that a lot of performance timing chains are shown with the cam and crank gears as a set. Is it necessary to change the gears if you want to upgrade/replace the timing chain - like to an LS2 timing chain and you don't need adjustable timing gears?
Seems to me that the chain alone would be fine if the gears are not worn.
Old May 8, 2008 | 02:54 PM
vettenuts's Avatar
vettenuts
Correct, LS2 is the stock replacement chain. Katech is a better chain than LS2, which will fit stock gears as well.
Old May 8, 2008 | 06:28 PM
SDPC's Avatar
0SDPC
Former Vendor
C'mon, just once I want you to link this!
http://www.sdparts.com/product/SD3SR...ollerIwis.aspx
Old May 8, 2008 | 07:20 PM
vettenuts's Avatar
vettenuts
Damn, keep forgetting. Perhaps a sample will jog my memory
Just kidding
Make sure you keep me posted on when that new Cloyes with Torrington comes out, I have a parts list ready for you guys and will add that as well since my install is now planned for October.
Old May 9, 2008 | 02:19 PM
EStreeter's Avatar
EStreeter
So which is better?
Katech, Iwis or stock LS2?
Old May 9, 2008 | 03:14 PM
SDPC's Avatar
0SDPC
Former Vendor
I believe the Katech is an Iwis as well. Both ours and the Katech are both superior to the LS2
To Timing Chain Question
