"Tests on the LS1-GT2-3 have shown 25-30 HP improvements over factory LS1, LS2 camshafts and this camshaft can be used in 350 CID - 427 CID applications. This camshaft also works well in supercharged or turbocharged applications."
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Originally Posted by prochgedc5
thank you i have a zo6 cam now but i want to step it up
If you have a Z06 cam in an LS1 with LS1 heads (99 frc in your profile), then you must have changed the push rods to longer ones since the Z06 cam has a smaller base circle.
Your going to need to check depth and probably go with the 7.4's again.
