Holy Shift????
Old May 9, 2008 | 07:59 PM
silver shadow's Avatar
silver shadow
8th Gear
Default Holy Shift????
I have a shifter problem w/ my 02 the last 2 days I have to put my car in nuetral and back into park to start it and the gears are confused park is sometimes reverse which can really cause a problem,any ideas what might cause this.
Old May 9, 2008 | 09:26 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Do these cars have a neutral safety switch? My old Taurus did something like that, and the NSS was the problem.
Old May 10, 2008 | 10:17 AM
silver shadow
8th Gear
Thanks I did think about that and have a friend who is checking on that for me.I thought there might be a computer issue .
Old May 10, 2008 | 11:12 AM
BlackZ06's Avatar
BlackZ06
There is a switch on the outside of the transmission called the "Park Neutral Position" (PNP) switch. The switch reports to the PCM on what gear has been "selected" by the driver. It is how the PCM "knows" the car is either in Park or Neutral for engine start.
You can replace the PNP without having to remove the tranny. You will need to lower the left side exhaust to get to the PNP. The other thing is that installing the new switch requires careful alignment to ensure that when the tranny is in Neutral that is the position the PNP is reporting also.
Old May 10, 2008 | 08:49 PM
silver shadow
8th Gear
Thanks so much for the help,the members of the C/F are so helpful .Monday my day is planned out, Im very motivated to fix this problem my backup is a buick real head turner.
To Holy Shift????
