im not clever enough
Old May 10, 2008 | 06:58 PM
wettvette's Avatar
wettvette
Default im not clever enough
could someone please tell me what this code means 10-pcm PO200 C.
The car does get a mis-fire that comes and goes. Also does the car need a special coolant and if so what do i look for in a coolant , because i live in New Zealand brand names are no good to me, i need to know what makes it suitable for the corvette. i heard somewhere that you cant put any old coolant in there. And what about good old fashioned water?
Old May 10, 2008 | 07:49 PM
hotwheels57's Avatar
hotwheels57
http://www.corvettedoctor.com/Code_Main.html
Old May 10, 2008 | 08:25 PM
Chicago1's Avatar
Chicago1
^ That should be a sticky unless I am not seeimg it anywhere.
Old May 10, 2008 | 11:32 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
It believe you should be able to flush out the entire cooling system with water and then replace it with any 50/50 mix of generic antifreeze and distilled water. You can't mix Dexcool ( the orange stuff) with just any antifreeze. It will coagulate.
To im not clever enough
