Need Help ASAP - P0300
Old May 10, 2008 | 09:49 PM
SRVVR's Avatar
SRVVR
Default Need Help ASAP - P0300
Just driving around tonight, ended up sitting with the engine running for a bit, and there was NO harsh driving. I barely got it above 3K RPM.
Anyway, started riding a bit rough and I noticed when I got on it, it was a bit louder than normal. Sounded similar to an exhaust leak, only not as raspy. The roughness got more noticeable, and the RPM's started bouncing around, both at idle and when I took off. Finally, the CEL started blinking at me, I pulled over, killed the engine, and checked the codes to see P0300. Babied it back home, was only 2 miles from the apartment, and pulled it in the garage. The whole way home, I was backfiring, and the RPM's were not cooperating, as they would bounce constantly, but I kept it under the 3K mark all the way back.
It's in the garage now, and I'm not sure where to start. I'm letting the engine cool off a bit before I start digging around, but does anyone have any suggestions. I don't have any beer over here, otherwise I'd offer beverages in exchange for a visit.
Any and all help would be greatly appreciated.
Old May 10, 2008 | 09:51 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
loose air bridge?? to much air/unmetered air??
check your plug wires also may have a bad one
Old May 10, 2008 | 10:08 PM
wettvette's Avatar
wettvette
i have the same but with a PO200 ??
Old May 10, 2008 | 10:27 PM
Tigershark3's Avatar
Tigershark3
Check your plug wires... Last time I had that code w/ the CEL blinking it was one of my wires at the plug.
Old May 10, 2008 | 11:42 PM
SRVVR's Avatar
SRVVR
Well, shortly after getting the fuel rail cover off, I found the culprit plug wire. It was not dangling, but it was literally just resting up against the plug. Now my question is, why did a plug wire come loose? I connected it back up, fired up the engine, let it idle without any problems, and then pumped the throttle without any problems. Any idea why I would have had a plug wire get knocked off like that? My "practical" knowledge of engines is minimal, so keep it simple, and I'll ask for clarification if needed.
Thanks for all your help.
Old May 11, 2008 | 12:32 AM
T VETTE's Avatar
T VETTE
Is hard to say why, unless it was worked on and was left loose or could be it has been a little loose for some time and just it's time to reach the no go point. You should be fine not really a big thing, you found it quick good job!
Old May 28, 2008 | 09:34 AM
SRVVR's Avatar
SRVVR
Well it's been some time now since I got the plug wire back on, but it's been holding since. The car is now at Quality Motorsports for some "minor" upgrades, I'll post more later...
Thanks for everyone's quick help on this.
To Need Help ASAP - P0300
