C5 Bose Radio
Also does anyone have instructions for taking off the door panel? Just the location of the screws.
Thanks!
-Jeff
Post this in the audio section. You'll get more replies.
Good Luck
See Below for Trim Removal
Document ID# 218586
1999 Chevrolet/Geo Corvette
Trim Panel Replacement - Door
Removal Procedure
To reduce the chance of damage to the trim panel leave the switch in the panel until after the panel is removed from the door.
Lower the door window.
Remove the inside handle bezel. Refer to Handle Bezel Replacement - See Below
Remove the pull handle plug.
Remove the screws behind the pull handle plug.
Important
To avoid breaking the trim panel fasteners be sure to insert the fastener removal tool between the male fastener, which is attached to the trim panel, and the female retainer which is in the door. Do Not insert the tool between the head of the female retainer and the door.
For better sight access to the fasteners start by first prying out the fastener at the rear of the trim panel that is approximately 50 mm (2 in) up from the trim panel seam. Pry out the remaining trim panel fasteners working your way forward.
Lift the trim panel up off the upper retainers and reposition the panel by the door.
Remove the harness connector from the switch.
Remove the trim panel with absorber, switch, and speaker grill.
Remove any trim panel upper retainers that remained on the door.
Transfer parts as necessary.
Installation Procedure
Reinstall any loose upper retainers to the door trim panel.
Position the trim panel near the door and install the switch harness to the switch.
Install the trim panel to the top of the door engaging the upper retainers.
Align all the trim panel side and lower fasteners with the retainers in the door.
Press the trim panel firmly to the door at each fastener location.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the screws behind the pull handle. Tighten
Tighten the pull handle screws to 6 N·m (53 lb in).
Install the pull handle plug.
Install the bezel to the handle.
Position the bezel around the inside door handle.
Push firmly on the bezel engaging the bezel locking tabs to the door.
Document ID# 218586
Document ID# 99224
Handle Bezel Replacement - Inside
Removal Procedure
Pull the door inside handle open to access the openings to the bezel locking tabs.
Insert a screwdriver in the lower opening. Tip the screwdriver up while pulling on the bezel releasing the lower locking tab.
Insert the screwdriver in the upper opening. Tip the screwdriver down while pulling on the bezel releasing the upper and the forward locking tabs.
Grasp the bezel firmly, pull the bezel releasing the rear locking tabs.
Remove the bezel.
Document ID# 99224
Document ID# 312081
Speaker Replacement - Front
Removal Procedure
Remove the door trim panel. Refer to Trim Panel Replacement - Door in Doors.
Disconnect the electrical/audio connector from the front door radio speaker assembly.
Important
The speaker assembly is only held in place by retaining screws. Be sure to support the speaker assembly upon removal.
Remove the screws retaining the front door speaker assembly to the door.
Remove the front door speaker assembly.
Install the front door speaker assembly into position in the door.
Notice
Important
The tightening sequence MUST be followed.
Install the front door speaker assembly retaining screws in the following sequence:
The uppermost screw
The lowermost screw
The remaining screws in a criss-cross pattern Tighten
Tighten the front door speaker assembly retaining screws in sequence to 2.5 N·m (22 lb in).
Connect the electrical/audio connector to the front door speaker assembly.
Install the door trim panel. Refer to Trim Panel Replacement - Door in Doors.
Document ID# 312081
