Squeak Belt HELP!!
Old May 12, 2008 | 12:07 PM
slverbulletz06's Avatar
slverbulletz06
Default Squeak Belt HELP!!
Ok i searched & Searched for a forum that could help me but still havent found one!! I have changed My Tensioner, the idler pulley and i dont run a ac belt so it couldnt be that it sounds like it is comming from the right driver side of the motor, and it starts whenever i accelerate and when i slow down and put it in nuetral it just quits i have no idea what it could be!!
Old May 12, 2008 | 12:19 PM
ragtopws6's Avatar
ragtopws6
Have you tried replacing the BELT?
Old May 12, 2008 | 12:23 PM
slverbulletz06
Yup I replaced the belt
Old May 12, 2008 | 12:32 PM
ragtopws6's Avatar
ragtopws6
Try putting on a small amount of silicone on the belt and run it. If the noise goes away, then it's your belt.
If the noise is still there, try using a long screw driver and listen to the handle while you put the other end to where the noise might be (pulleys).
Old May 12, 2008 | 01:22 PM
slverbulletz06
Well i did the screw driver thing u told me to do and the alternator and tensioner are just fine so im thinking it might be the water pump. Man its just one thing after another with this car i feel like i should just trade it in
Old May 20, 2008 | 12:03 AM
slverbulletz06
Alright Guys i changed the water pump and it didnt go away
Old May 20, 2008 | 09:12 AM
kas61's Avatar
kas61
Did you put a Gatorback belt on?
Old May 20, 2008 | 09:31 AM
slverbulletz06
no ac delco bu its a brand new belt, should i get a gator belt , some people say its more a vibrating noise
Old May 20, 2008 | 09:40 AM
kas61's Avatar
kas61
I put a Gator on mine and it stopped the squeaking. The belt I took off was new also, Put in the trunk for a spare.
Old May 20, 2008 | 09:58 AM
vicsvette's Avatar
vicsvette
Navigator
Default Sounds familiar
Im getting a similar sound with my Vette but its kinda weird it will squeel a bit on and off but only at about 1500 rpms. above or below it goes away. I havent figuered wher its coming from or even if its the belt? But it sounds like a belt squeel. so If you figure it out Ide like to know what it was...thanks
Old May 20, 2008 | 10:11 AM
slverbulletz06
Ill put one of those belts on and hope it works.
Old May 20, 2008 | 10:38 AM
slverbulletz06
Mine Squeals in high rpms only! its pissin me off though bc i cant find what it is i probly bought every pulley u can and it still does it!
Old May 20, 2008 | 02:18 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
I had this with two different C5s, gatorback main and AC belts took it away on both cars.
Cajun
Old May 20, 2008 | 08:33 PM
tony2003's Avatar
tony2003
Default gatorback yes
put napa belt on new after water pump and squeak began talked to a mechanic and he said change to gatorback sound now gone tony
Old May 21, 2008 | 11:52 PM
slverbulletz06
Sweet Alright Thanks Guys i have ordered mine and it should be in tomorrow. I really appriciate all the advice
Old May 22, 2008 | 12:32 AM
AutoMag's Avatar
AutoMag
I had a small "chirp" at idle. I took it in and they replaced the alternator under warranty, but after driving it for less than 100 miles, it came back. I'm going to take it back in and will let you know what they find.
Old May 22, 2008 | 09:15 AM
slverbulletz06
Sweet! I took a long screw driver and listened to the alternator and i couldnt hear a squeal but whenever i do just take the belt off and turn it and back and foward it kinda makes a squeal but i dunno lol
Old May 22, 2008 | 02:49 PM
slverbulletz06
ALRIGHT IT WORKED!!! Thanks for all the advoce guys i really really do appriciate IT!!!!!!! GATORBACK is the way to go!!!!
Old May 22, 2008 | 03:07 PM
VIPERBLUELX's Avatar
VIPERBLUELX
Due to EPA regulations the belt manufacturers have changed the compound of the rubber which cause most of the newer belts to make more noise. Dayco just came out with a new design with a patented "W" groove that they guarantee not to squeal, it also has their version of teflon in the belt. They look really nice.
To Squeak Belt HELP!!
