Tons of codes......thoughts?
Old May 12, 2008 | 05:46 PM
Bull_in_a_china_shop's Avatar
Default Tons of codes......thoughts?
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
U1096 Loss of Communications with IPC
U1064 Loss of Communications with BCM
U1016 Loss of Communication with PCM
C2100 Left Front TPM Sensor Malfunction
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
PO444 <- wasnt able to find........
We just did a trans/clutch/diff install in the car btw
Old May 12, 2008 | 07:30 PM
aquaholic's Avatar
aquaholic
bad battery, corroded ground lug on frame or burnt contacts in ignition switch. start with the battery test and torque the terminals to 11 ft-lb. next check ALL of your ground points (theres a bunch) last check would be the ignition switch contacts.
Old May 13, 2008 | 01:43 AM
DeeGee's Avatar
DeeGee
If they are H codes clear them out and see if any come back.
Old May 13, 2008 | 06:36 AM
aleadfoot's Avatar
aleadfoot
What is the condition of the battery charge
To Tons of codes......thoughts?
