A4 automatic 3.42 rear end
Old Dec 17, 2001 | 05:19 PM
WHY2KRAG's Avatar
WHY2KRAG
Default A4 automatic 3.42 rear end
Is there any difference between an A4 or 6 speed when chosing a rear end gear set. Complete pod assembly. Should I be concerned ? :confused: :cheers: :seeya
Old Dec 17, 2001 | 06:25 PM
WHY2KRAG's Avatar
WHY2KRAG
Default Re: A4 automatic 3.42 rear end (WHY2KRAG)
TTT
Old Dec 17, 2001 | 06:42 PM
vstella's Avatar
vstella
3'42's are 3.42's.A4 or M6. In fact the 3.42'a are std equip. on all 6 speeds.:D
Old Dec 17, 2001 | 07:03 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: A4 automatic 3.42 rear end (vstella)
Yep, Vince is right! :yesnod:
Old Dec 17, 2001 | 10:12 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
What do you have now?
Old Dec 18, 2001 | 07:02 AM
WHY2KRAG's Avatar
WHY2KRAG
Default Re: A4 automatic 3.42 rear end (wallstAL)
I now have stock 2.73 gears. Switching out to 3.42 should be a sotp difference I hope hope hope :cheers:
Old Dec 18, 2001 | 08:06 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Save a few install $$$ by installing a SY 3500 at the same time. :yesnod:
Since GM offers a 'performance axle' option, I never understood why they don't use the 3.42 instead. :confused:
Old Dec 18, 2001 | 09:00 AM
Austrian Vette's Avatar
Austrian Vette
Default Re: A4 automatic 3.42 rear end (Sully C5)
The 3.42 will wake up your car for sure, but as Sully C5 said, do a converter the same time. It´s nearly the same labour and you will be happy.
A SY3500 is a perfect streetconverter.
SY3500 + 3.42 and you will not believe that you are sitting in the same car as bevore the changes!!
Michael
Old Dec 18, 2001 | 11:18 AM
2000^C5's Avatar
2000^C5
Default Re: A4 automatic 3.42 rear end (Austrian Vette)
Ditto, I have 3.42s and a SY 3500, the combo is great on the street!
Old Dec 18, 2001 | 11:21 AM
Humy's Avatar
Humy
Default Re: A4 automatic 3.42 rear end (2000^C5)
what does something like that cost these days, with a used 3.42 setup for say $500
SY 3500 torque converter=cost?
instal=cost?
:cheers:
Old Dec 18, 2001 | 11:29 AM
jawski's Avatar
jawski
What do you mean by "great on the street" I'm considering this mod but thought lower rpm lock up, 2400 or 2800 rpm, would be more suitable for daily driver's.
Old Dec 18, 2001 | 11:38 AM
jawski's Avatar
jawski
Default Re: A4 automatic 3.42 rear end (jawski)
oops,:bb just read the earlier post on TC's.
Old Dec 18, 2001 | 06:18 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Sully C5---Good thought, & many of us A4 people would buy this in a heart beat, but, it's all about CAFE miles per gallon corporate Gov't mileage results. The General could do this IF they wanted---But they never will....We are lucky to get the 3.15 gears, let alone 3.42 gears....Regards.
[Modified by BiggieBoy, 4:21 PM 12/18/2001]
Old Dec 18, 2001 | 06:27 PM
2000^C5's Avatar
2000^C5
Default Re: A4 automatic 3.42 rear end (Humy)
instal=cost?
:cheers:
Converter will be around $800 I think and install should be around $600 for both. It is not an easy job.
To A4 automatic 3.42 rear end
