Spark Plug Boot Pliers
Old May 12, 2008 | 07:10 PM
02MillenniumVette's Avatar
02MillenniumVette
Default Spark Plug Boot Pliers
This has been posted before but the only answer was to use your hands and I dont want to do that again. Can anyone recommend one of these pliers to use? Thanks.
http://buy1.snapon.com/catalog/tools...e=snapon-store
Old May 12, 2008 | 07:39 PM
aquaholic's Avatar
aquaholic
i use a $5 pair of needle nose. the 12" long ones that have the ends bent into a circle. i'de go with the cheapest ones. they all look like they would work fine.
Old May 12, 2008 | 09:09 PM
jrprich's Avatar
jrprich
http://www.monstronix.com/advanced_s...T135&x=13&y=12
Brand Name : KD Tools
Model Number : KDT135
Product Desc : Spark Plug Terminal Plier
Quantity : 1
Price/Unit : 7.79 shipped
Old May 12, 2008 | 09:18 PM
hawk4077's Avatar
hawk4077
got a set from sears work really well
Old May 12, 2008 | 10:01 PM
02MillenniumVette
Thanks for the help.
Old May 12, 2008 | 11:00 PM
djengr's Avatar
djengr
I got a pair from autozone, they weren't worth a $@$%^. I bent them the handles on about the fourth or fith plug. Kept on having to un bend. I think the were in the $5-$7 range. I like the needle nose from a few threads up.
Good luck
Old May 13, 2008 | 05:39 PM
FullOutPwr's Avatar
FullOutPwr
I guess I may be the only one who doesn't use them... I just reach my hands in and wiggle the boot until it comes off.
Old May 13, 2008 | 05:44 PM
SLPRC5's Avatar
SLPRC5
Here is a trick for next time.
Use di-electric grease inside the boots, this keeps them from sticking.
Old May 14, 2008 | 02:40 AM
dieseldave56's Avatar
dieseldave56
Default di-electric for sure the next time............
I use a couple of different plug pliers, straight and bent, but the real help comes from a few long , small diameter flat blade (I have rounded off the edges and tip) screw drivers that I bent the tips back 180 degrees to access the front of the plug boot and 'break' the contact seal with the ceramic plug body. I just reach down and hook the boot and rotate the screw driver tool as far as I can either way. Then the plug boot usually just pulls off.
Old May 14, 2008 | 08:23 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi 02MillenniumVette -
I bought the sears pliers - they were $15 and are great quality.
Here is a link to a write-up that I put together - please use internet explorer to view it as firefox does not like my custom code:
http://www.iammoon.com/c5tech/c5_plugs.htm
best regards -
mqqn
stingray71's Avatar
stingray71
I bought some to use when changing the plugs a few weeks ago. They were useless as I couldn't get enough leverage and found it was easier to use my hands (wearing mechanics gloves).
Old May 14, 2008 | 11:33 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Reach down with your hand and firmly grasp the spark plug wire boot, then give it a good twist.
Old May 14, 2008 | 12:28 PM
craig04c5's Avatar
craig04c5
twisting if you can is the key. As I recall I could not twist a couple of hard to get to ones on the drivers side rear near the airtube so I used a regular pair of pliers on the boot to try and twist & pull. I managed to get them all off without any damage.
Old May 14, 2008 | 12:41 PM
02MillenniumVette
best regards -
mqqn
Thanks. Those are the ones I bought yesterday.
To Spark Plug Boot Pliers
