Cant find the thread
Old May 12, 2008 | 08:00 PM
harleyvette's Avatar
harleyvette
Default Cant find the thread
I cannot find where the hockey pucks were on a thread and it showed the size of the eye bolts to use.
Would any one know? It might seem unimportant but I need them right away that is why I will make these, not enough time to buy and have shipped.
The c5 goes up on a hoist Friday.
THANKS
Old May 12, 2008 | 09:21 PM
Red99FRC's Avatar
Red99FRC
The ones I made, I used an eye-screw with the following dimensions:
Outside diameter of the eye - 1-1/4".
Inside diameter of the eye - 3/4".
The shank is 1-3/8" long. This will thread all the way through the puck, but you can screw it in or out to get a snug fit in the frame slots. Works better to drill a hole in the puck first - kind of hard to turn the eyescrew in without it.
Good luck... It's pretty simple.
Old May 12, 2008 | 10:28 PM
BlackZ06's Avatar
BlackZ06
Default BMW pucks
The BMW pucks are surprisingly cheap and once installed can be left on the car.
Go here and look at post #4 for where to buy and the BMW part number ....
http://forums.corvetteforum.com/show...ghlight=hockey
Old May 12, 2008 | 11:56 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
THANKS
Reminder -- 'hockey pucks' should only be used in the rear when using a 'hoist' -- per the manual.
For some 'light' reading on this subject (and more), here's a link to a write-up I did 2.5 yrs ago.
http://forums.corvetteforum.com/show....php?t=1255851
To Cant find the thread
