Double Din Mod
Old May 12, 2008 | 11:01 PM
Georgian's Avatar
Georgian
Default Double Din Mod
Has anyone modded the bezel for a double din on a tan interior (04 lemans ext, tan interior). Looking to find out what compound you used and paint to match the current color.
Old May 13, 2008 | 08:46 AM
GONZZO's Avatar
GONZZO
I believe C5 KIDD makes what you are looking for, here is a link to his online catalog. http://www.shop.ti-motorsports.com/p...&categoryId=36
Old May 13, 2008 | 09:48 AM
bbentley40's Avatar
bbentley40
Are you saying the console is tan? My car has tan interior and I have done a double din mod on it, but the console is/was still black.
Old May 13, 2008 | 10:49 AM
Georgian's Avatar
Georgian
Thanks GONZZO i've read that in the searches i did before posting but i'd rather do it myself if possible.
Ya the entire interior is Tan so i need to find a paint that will match.
Old May 13, 2008 | 10:52 AM
Casem1's Avatar
Casem1
Was that the commemorative edition? If I am reading this right then the same would apply to the 50th anniversary cars. I think GM called the interior Shale, they may have some dye.
Old May 13, 2008 | 12:16 PM
Georgian's Avatar
Georgian
Ya its the commemortive edition and the interior is infact shale, would the dealership be able to aquire a similar dye or should i be talking to someone at a body shop?
Old May 13, 2008 | 01:52 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
SEM makes interior dyes. You can take your part into a paint and body supply shop to have them mix it up. PPG has an interior dye system as well. I recommend you use Bulldog adhesion promoter and clean your plastic well to prevent fisheye and other adverse chemical reactions prior to applying the color coat. I would also recommend you clear it when you're done. There is a satin clear available if you desire. There may also be an interior color code they can use to match your paint.
To Double Din Mod
