Seat Problems
Old May 13, 2008 | 11:56 AM
texinmiC5's Avatar
texinmiC5
2nd Gear
Default Seat Problems
Hello All, This place is great. Have spent hours reading here, I am new to the forum, and hoping if someone can add some insight...I had both sport seats bottoms reupholstered, and now all the back controls do not operate, worked before I removed seats for the upholstery shop. Seems odd that both seats went out at the same time. Is there a connector maybe not connected...All other functions operate perfectly. All the connectors on the seat control box.(SCM ?) are connected and all the connections I could see from the underside are connected good. There is just nothing when you push the adjusting buttons. It is an '01 C5 Coupe w/memory seats and full lumbar support. I was very meticulous in separating the connectors on the seats and resetting them when seats went back in. The shop did a great job of beefing up the seat bottoms for me...feels like a new car now. I have only had it for about 4-5 weeks. Still in great shape for almost 80K miles...
Old May 13, 2008 | 10:00 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Take the seat out and check all of the connectors. You can get it out in 5 minutes.
Old May 27, 2008 | 09:07 PM
hoob33's Avatar
hoob33
4th Gear
You did not say whether you put the seats back together yourself. There is a small motor pump combination that runs the various lumbar bags. The pumps may not be running or disconnected from the bags. I had to replace my pump and used a cheap Ford pump which is the same. Listen to see if you hear the pump running or not. The seat is easy to take apart and do the repairs.
Old Jun 3, 2009 | 11:12 PM
barking orifice's Avatar
barking orifice
I have a new to me 8000 mile '00 with same seats. I have taken everything apart to put new seat covers on my seats. I have discovered that all but two of the elbows from the air tube to the bladder cushions has failed. the plastic is obviously faulty. I'm wondering how common my experience is as well. I'm buying all new bladders and installing them. it will be possible to get to them by removing the center section of the seat back. It would be a difficult job if you have not seen the seats all apart. Just wanted to share. Very ticked off by the lack of quality inside the seats.
Old Jun 5, 2009 | 06:48 AM
Jesse Asis's Avatar
Jesse Asis
Check the fuse, it is located at the foot well of the passenger seating against the firewall. I removed my drivers seat and for some reason upon re-connection of the connectors, it was dead, blew a 10 amp fuse for the driver seat. anyway check it out, if no wires are shorted out, it is a good bet the fuse popped. good luck.
Old Jun 5, 2009 | 07:07 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Check the fuse first...
To Seat Problems
