Coolant leak (help) !!!!!!
Old Jun 23, 2008 | 11:58 AM
Tormania's Avatar
Tormania
Cruise-In IV Veteran
Cruise-In V Veteran
Originally Posted by jedblanks
The coolant resevior is also known to leak under pressure where the "seam" is. See if you see any sign of orange dex cool residue on or around the coolant surge tank.
This is happening to my C5, but I can't tell if the seam is at fault as it appears the leak starts at the top surge hose where it clamps to the surge tank, then runs down the surge tank and down the seam toward the front of the car.
I'm planning to replace the hose and clamp but I wonder if I should go ahead and replace the tank while I'm at it. My car has 107K miles on it.
Old Jun 23, 2008 | 12:55 PM
Lancer033's Avatar
Lancer033
Originally Posted by Cujo67
Check the coolant tubes on the front of the heads. You may have a bad gasket.
what happened to me, new gaskets and move on down the road
