code c1214 H C
Old May 14, 2008 | 02:50 PM
skipsvet's Avatar
skipsvet
1st Gear
Default code c1214 H C
Well I got my 03 zo6 2wks ago its great but I got this code c1214 h c I guess I have to pull the part and send it abs fixer
Old May 14, 2008 | 02:54 PM
Bill Dearborn's Avatar
Bill Dearborn
That is correct. However, there may be another problem that led to this one. The diagnostic procedure says to check the following:
Disconnect the pump motor harness pigtail connector of the BPMV.
Measure the resistance between each pump motor control circuit and the housing of the BPMV at the pump motor harness pigtail connector of the BPMV.
Does the DMM display the specified value? The specified value is overlimit or infinity. If so then you just need to get the EBCM fixed. But if it doesn't read over limit or infinity then you need to replace the BPMV as well.
Bill
Old May 14, 2008 | 02:55 PM
SUPERCRUZ's Avatar
SUPERCRUZ
First, try cleaning all the ground connections in the engine compartment. Then, you may want to try pulling the main wire harness off the EBCM and making sure it is clean and not damaged in some way. Reconnect everything and see if you can clear your code. If not, pull the EBCM and send to ABS Fixer. Just sent mine there about a month ago. Great turn around and customer service. Good luck with it.
Old Jul 13, 2017 | 09:57 PM
Camaroboy44's Avatar
Camaroboy44
2nd Gear
Default 1214c codes
I got the same code but everyone say it disables those systems my tsc just stays on anyone else have this problem?
Old Jul 16, 2017 | 05:21 PM
Bill Dearborn
It does disable ABS, TC and AH. The relay that provides power to the brake pressure modulator valve can't reliably supply sufficient voltage to operate the pump motor inside the module so the complete system is shut down until the problem is fixed.
Not sure what TSC is.
Bill
Old Jul 17, 2017 | 05:57 AM
SG Lou's Avatar
SG Lou
Originally Posted by 8VETTE7
Does not have to be a bad relay in the EBCM. There are several other possible causes of voltage not being sufficient:
https://www.corvetteforum.com/forums...de-1214-a.html
Post #3.
Post #4
To code c1214 H C
