I ordered Z06 sway bar set
Old May 14, 2008 | 11:00 PM
ILM-Express's Avatar
ILM-Express
MFIC
Default I ordered Z06 sway bar set
Just finished installing the rear, tommorow the front.
Old May 14, 2008 | 11:14 PM
californiakid's Avatar
californiakid
Is that the C5 Z06 or C6 Z06 set? I have the T1's on my car and I can tell you that road handling improved vastly with the bigger sway bars.
Californiakid
Old May 14, 2008 | 11:19 PM
ILM-Express
MFIC
I'm going from 1999 C5 Z51 to 2004 C5 Z06
Old May 15, 2008 | 08:31 AM
stormrider's Avatar
stormrider
That was my first mod. You are going to love the results
Old May 15, 2008 | 10:05 AM
LoneStarFRC's Avatar
LoneStarFRC
Same here. If you install a C5 Z06 rear spring, you'll love it even more.
Old May 15, 2008 | 10:16 AM
MagRedConv's Avatar
MagRedConv
I did the full mod - C5 Z06 springs front & rear (lowered) & C6 Z06 shocks & sways; night and day.
Old May 15, 2008 | 04:44 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
you going to love those sway bars
Old May 15, 2008 | 04:57 PM
914eener's Avatar
914eener
Upgraded from FE3 to Z06. Made a huge difference!
Old May 15, 2008 | 05:02 PM
BUGZ's Avatar
BUGZ
I also have the 99 Z51. Please update how your ride changed when your done. I'm alway looking for a another mod to consider
Old May 15, 2008 | 05:29 PM
ILM-Express
MFIC
I'm going autocrossing on sunday I'll let you know that afternoon.
Old May 15, 2008 | 06:28 PM
motogib1's Avatar
motogib1
Z06 Sways were the best bang for the buck mod for my 02 coupe.
Old May 15, 2008 | 08:22 PM
Chuck01's Avatar
Chuck01
You will notice the difference asap
Old May 15, 2008 | 08:23 PM
Chuck01's Avatar
Chuck01
The ride is much sharper and you will love the difference.
Old May 15, 2008 | 09:26 PM
lionelhutz's Avatar
lionelhutz
I take it your car has the 25mm front / 21.7mm rear bars?
I've read the early bars are as above and the later Z51's had 28.6mm front / 23.6mm rear. I'd like to see that confirmed though.
The C5Z06 bars are 30mm front / 23.6mm rear. If you're swapping the later bars then there won't be much difference. The car will likely tend to under steer in either case hence the recommendation to change to the C5Z06 rear spring which balances it out again. Front spring Z06 or Z51 is the same.
At least that's the info I've found on bar sizes.
Peter
Old May 15, 2008 | 11:16 PM
corvettejoe98's Avatar
corvettejoe98
Just did mine on monday and wow the car corners so good. I may do Z06 springs next to get a little more and out of the suspension.
Old May 15, 2008 | 11:30 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Old May 15, 2008 | 11:46 PM
jrose7004's Avatar
jrose7004
I want to do that mod!
To I ordered Z06 sway bar set
Old May 17, 2008 | 12:18 PM
ILM-Express
MFIC
A few days late but I finished the front
Old May 17, 2008 | 11:09 PM
c3spdrcr20's Avatar
c3spdrcr20
Well?
Old May 18, 2008 | 06:33 AM
ILM-Express
MFIC
So far the car feels like it's on rails.
Going from fatigued Z51 to new Z06 is like night and day.
When I come back from autocrossing today, I'll be able to tell you some more....
