I have serial data comm problems!!
Old Jun 21, 2008 | 06:54 AM
Greg_E's Avatar
Greg_E
I've never had to replace the BCM, but from what I read, you need to have the BCM programmed to match the options on your car. As far as I know, only the dealer can do that, unless you find someone that has a Tech 2 ( the programmer/diagnostic tool that the dealer uses).
Old Jun 21, 2008 | 09:15 AM
BlackZ06's Avatar
BlackZ06
The dealer is the best answer. Even if someone has a Tech2, unless they have access to the GM TIS it is probable that some feature would be missed. The dealer "simply" enters your VIN and which module is to be programmed and TIS downloads the "correct" configuration for your car based on the build records, and also includes any software updates that apply to the module.
Also, I bet frohara has his airbag warning light on (airbag system is disabled) and a B1001 set ... that will have to be fixed also by the re-programming.
Old Jun 27, 2008 | 10:31 AM
frohara's Avatar
frohara
Yes, you are 100% correct. I do have a B1001 code and the air bag warning light is on.
A trip to the dealer is in order.
Thanks for all your help guys.
Old Sep 21, 2008 | 12:48 PM
ROJO99's Avatar
ROJO99
I am issues with the PCM, No Comm. The PCM seems to be locked. If I eliminate the gorund will the PCM be able to be seen or communicated with?
