help! Check Valve replacement
Old May 15, 2008 | 11:43 AM
NO CHNCE's Avatar
NO CHNCE
Default help! Check Valve replacement
I have a check engine light on and code is P1415 which indicates left side check valve. Parts store can supply part, but is there a special tool required to remove an unusual plastic? hose clamp that connects to the check valve? Thanks
Old May 15, 2008 | 12:25 PM
jirasvet's Avatar
jirasvet
Default Be careful
No special tool, just use a screw driver or pick to lift and seperate.
Squeeze back together to reuse.
Old May 15, 2008 | 03:04 PM
vettenuts's Avatar
vettenuts
I use my fingers, or I used to when my fingers still worked
To help! Check Valve replacement
