C5 Headlamp Motor Headaches
Old May 15, 2008 | 09:54 PM
jjh3349's Avatar
jjh3349
Default C5 Headlamp Motor Headaches
My 1998 Headlamps worked perfectly and then with no indication both Headlamp Motors stopped working, can not even hear a motor noise. Checked all information recently posted by Mr. Curlee and gmblack3. Very stumped, need serious help. Could it possibly be the switch on turn signal lever ?
jchebert@***.net
Old May 15, 2008 | 10:01 PM
ol bennie's Avatar
ol bennie
not likely on the switch but i will say stay away from putting brass gears in imo
Old May 16, 2008 | 03:18 PM
DeeGee's Avatar
DeeGee
First thing to check is fuse #6 in the passenger footwell
Old May 16, 2008 | 10:37 PM
DashingDaryl's Avatar
DashingDaryl
Headlight Controller? (The little box under the Passenger Side Headlight)
Either it went bad, or maybe you unplugged the wires while changing a light bulb?
Old May 23, 2008 | 08:18 AM
jjh3349's Avatar
jjh3349
Thanks DashingDaryl, new controller cured the problem. Jerry
Old May 23, 2008 | 01:53 PM
DashingDaryl
EXCELLANT! Glad I could help!
Old May 23, 2008 | 02:08 PM
mvarga's Avatar
mvarga
I have a different problem. I replaced one of the motors last year. Now, the same light makes a nasty "ratchetty" sound when I lower it,even though it works perfectly. It's been doing this for about 6 months.
Old May 23, 2008 | 02:13 PM
Gearbanging101's Avatar
Gearbanging101
Sounds like your plastic gears are going bad. Look into some brass ones. There is a sticky on here with a "how to" replace them.
Old May 23, 2008 | 02:16 PM
mvarga's Avatar
mvarga
Thanks for replying. The problem started only a few months after I replaced the passenger side motor. It works fine, yet makes that really annoying sound. I'll look into changing the gears. Thanks!
To C5 Headlamp Motor Headaches
