MISSFIRE and codes
Old May 16, 2008 | 01:13 PM
PETE O.'s Avatar
PETE O.
Default MISSFIRE and codes
HELP!!!
Changed the plugs and wires in my `01 and Now I've got a check engine light and a missfire. I'vechecked the wires and they all seem to be on good. I checked the DIC and It's showing PO300, 1416, C1221,
C1222, C1248. Then it shows "28-TCS 3 CODES".
Can someone please shed some light on this for me!
Thanks!
Well, went out and checked the plug wires again and lo and behold #8 wasn't on tight . The missfire is gone but I still have a Check Engine Light that I never had before. The codes have changed somewhat. I'll have to jot them down again. They display faster than I can write, heh, heh......
Old May 16, 2008 | 01:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PETE
Please retrace your maintenance.
What plugs and gap did you use?
Are the insulators cracked?
Are the BOOTS fully seated on the coil towers and on the plugs? Recommend inserting the small flat end of a tie wrap into the coil boot while pushing it on the coil tower. That will allow the air to burp out. Once its fully seated (it will click twice) remove the tie wrap.
What wires did you use?
Have you tried to clear the DTCs and see if the other ones come back?
BC
Old May 16, 2008 | 02:16 PM
PETE O.'s Avatar
PETE O.
Originally Posted by Bill Curlee
PETE
BC
Thanks BC! Yeah, #8 wasn't clicked on to the plug. Using MSD wires and Delco Iridiums at .040. Still have that darned C.E.L. though. I've reset several times???? I'll go out and see if I can write all down. Shoulda taken shorthand 50 years ago......
Old May 16, 2008 | 02:32 PM
simpleman68's Avatar
simpleman68
Bill has been saving the day for many of us for some years now.
Hey Bill
Scott
lucky131969's Avatar
lucky131969
If I'm not mistaken, P1416 is right bank AIR malfunction. Check the security of the hose going to the check valve that resides behind the intake manifold. You may have disconnected or disturbed something as the connection for the right AIR is obstructing free access to #7 spark plug.
BlackZ06's Avatar
BlackZ06
You don't need to do shorthand .....
Let the initial display of the codes complete .... then DIC says ...."
Manual Diagnostics" .... now is the time to start writing down the codes ....... In the "MANUAL" mode you may select a particular module by pressing the "options" button to go forward or the "trip" button to go back. Once a system is selected and a DTC is displayed, if more than one are present; press "gages" to move forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M". If you want to erase or "clear" codes, press and hold "reset" until the code deletes.
Old May 16, 2008 | 03:36 PM
PETE O.'s Avatar
PETE O.
[QUOTE=BlackZ06;1565489567]You don't need to do shorthand .....
[/QUOTE
You folks are totally awesome!!!!
Thank you very, very much!
Old May 16, 2008 | 04:49 PM
PETE O.'s Avatar
PETE O.
Wow, these C-5s are almost as smart as the members here. That worked perfectly, and no need for shorthand. I checked the hose connections by #8 and redid them, just in case.
the codes it threw are:
AOLDCM--- B2282H
B2284H
U1064H
A1RDCM--- B2283H
B2285H
BORFA--- C2100H
28TC3--- C1221H
C1222H
C1248H
10PCM--- P0300H
P1416H
Can you identify any of these? I reset everything and the C.E.L. went off. Purrs like a kitten.........
Again, I sure do appreciate the sharing of knowledge and any help you can throw my way
Thanks,
Pete O.
Old May 16, 2008 | 06:28 PM
BlackZ06's Avatar
BlackZ06
Pete,
Nope ... these cars aren't "almost as smart as the members here" ... in many cases the car is WAY smarter than the member .....
OK, so you deleted the codes after writing them down. That was smart. Tomorrow I want you to go in and run the diagnostic again. List any/all DTC that are now in the car's computers and post them. Any "new" codes are worth looking into. Someone can look up the codes and then help you in diagnosing/fixing them.
You should check for codes occasionally. Some codes can set that won't turn on warning lamps, but can give you a "hint" of an upcoming problem. The codes can help you in keeping the reliability of your Corvette "high" as they can help spot minor problems before they become "major".
On the other hand, regular inspection and maintenance is still important. There are no codes for "radiator hose gonna split next Thursday" or "Serpentine belt gonna break in 20 minutes" .... but if a certain sensor is gonna fail in a few weeks it will usually cause some DTC to set long before it fails completely as it intermittently spews "bad" data.
Looking forward to a short list of codes (if any) .....
Old May 16, 2008 | 07:33 PM
PETE O.'s Avatar
PETE O.
Pete,
Thanks again! I'll check it out tomorrow after I go for a little drive. This Vette is certainly smarter than it's owner! Would a person find this info in a service manual? I've bid on a couple but I din't win them. Wasn't checkin the puter often enough, I guess. Anymore I get on this forum to just look around most every day. Surprising how much you can learn, if you pay attention....
Old May 16, 2008 | 07:56 PM
BlackZ06's Avatar
BlackZ06
Sent you a PM about your DTC ... so check for that ....
On the Service Manuals .... if you want to work on the car yourself they are invaluable. You can order them from the "manufacturer" ...
http://www.helminc.com/helm/homepage.asp?r=
Helm is the publisher for GM .... these are the manuals that are distributed to the dealers .... you can also order them from
http://www.gmpartshouse.com
Same manuals as from Helm ... just they discount them a little ....
Regardless ... be certain to get the manual for YOUR MODEL YEAR .... there are subtle changes in the C5 year to year so it is important to get the one for your car.
Old May 17, 2008 | 06:09 PM
PETE O.'s Avatar
PETE O.
Pete,
Hello, Steve!
It's a very short list
The only thing that came up after 200+ miles today was BORFA---
C2100H. I think you wrote that the RFA is Remote Funtion Indicator. (key bob, etc.) I don't believe you mentioned the BO prefix. How serious is it, Doctor?
Thank you very much for all the help
Pete O.
Old May 17, 2008 | 06:12 PM
PETE O.'s Avatar
PETE O.
Again, I thank you! I'll get `em ordered Monday!!
Thanks,
Pete O.
Old May 17, 2008 | 07:58 PM
BlackZ06's Avatar
BlackZ06
Hello, Steve!
Pete O.
Oh Nooooooooo ....
a C2100 .... step slowly away from the car ... make as little noise as possible .....
Nahhhhhh ... sorry .... only kidding .... (I'm a jerk) .....
C2100 Left Front TPM Sensor Malfunction
At some point during your drive the car was not receiving tire pressure data from your Left Front tire sensor.
Most likely the battery in the sensor is getting weak (they are supposed to last about 7 years). You will need to start thinking about replacing the sensors if they have not been replaced before.
Before replacing the sensors you need to follow my following recommended steps .....
1) Sit down in your favorite comfortable chair .....
2) Be sipping (gulping) down your favorite libation (mine is Johnny Walker Black Label)
3) Now you are ready to hear the price of new sensors .......
Let me know when you are ready .....
Old May 17, 2008 | 08:06 PM
BlackZ06's Avatar
BlackZ06
Sorry ... the B0 is an "arbitrary" number assigned to that module (computer). They have hexadecimal addresses ......
0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F
or appropriate combinations of those ...... a "donation" of $20.00 to the "Steve's party and toupee fund" will get you a further explanation of this ..... $25.00 and I throw in my "Welcome to Assembler Programming" manual ...... though it is written entirely in EBCDIC.
Old May 18, 2008 | 03:49 PM
PETE O.'s Avatar
PETE O.
Hi, Steve!
Hey, if I have to replace those sensors I won't be able to partake in my favorite libation (Gentleman Jack) anymore. I wouldn't be able to afford it. They all seem to be working okay at this point so I'll cross that bridge when it comes to me..... I'll go back to using a tire guage, not that I ever quit anyway. I've seen some posts on replacing the batterys. I guess if you had a tire machine in your garage it wouldn't be too bad, heh, heh.......
Thanks for the help, Steve!
Old May 18, 2008 | 07:23 PM
BlackZ06's Avatar
BlackZ06
Pleasure doing business with you ......
To MISSFIRE and codes
