Honker Installation
Old May 16, 2008 | 09:25 PM
tudland's Avatar
tudland
Default Honker Installation
I am currently installing a Honker in my '03 vert. I am stuck on getting the metal fasteners off of the push pins on the sides of the radiator shroud. Can anyone give me a way to remove those metal fasteners?
Thanks for any help.
Old May 16, 2008 | 10:58 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i used a real long narrow screwdriver and shoved it between the shroud and the frame and just pried the shroud away from the frame. took about 2 minutes to do both sides, after trying for a long time to do it any other way. went to the chevy dealer and bought 2 new push pins and locks. someone in the past said that you don't need these pins, but i replaced mine just the same.
Old May 16, 2008 | 11:40 PM
motogib1's Avatar
motogib1
These pins are used to hold the shroud on the production line and are not necessary. They do not need to be replaced. I use a very large screw driver to pry them off as well.
Old May 17, 2008 | 12:10 AM
PewtVette's Avatar
PewtVette
I left mine off as well.
Old May 17, 2008 | 12:33 AM
jornahow's Avatar
jornahow
I put mine back on - they were pretty buggered up by the time I got them off. If I did it again I would have new ones on hand and snip the old ones off instead of trying to pry them apart.
Old May 17, 2008 | 07:59 AM
tudland's Avatar
tudland
Thanks a lot for all of the answers. It looks like you solved my problem.
There is a lot of knowledge here and it is great that you all share it.
To Honker Installation
