Torque tube thump?
Old May 18, 2008 | 03:22 AM
vetteracerx's Avatar
vetteracerx
Default Torque tube thump?
On hard acceleration 1st and 2nd gear I get a loud thump sounds like it is in the TT? Bushings and bearings are new. Sounds just like the C3's did when the pinion mount would go bad. Thanks
Old May 18, 2008 | 06:28 PM
HP_Addict's Avatar
HP_Addict
I had a thump in my drivetrain and rebuild the torque tube and still had the knock. I pulled the engine and turns out, I have 2 cracked pistons. You might do a compression check.
Old May 18, 2008 | 10:26 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Damn I'll bet you'd rather have had a torque tube problem!! Nice to know I'm not the only guy with bad luck!
Old May 19, 2008 | 09:43 AM
HP_Addict's Avatar
HP_Addict
Tell me about it. When it rains it pours. What I thought was going to be a $300 repair has turned into a $5k investment.
Old Jun 9, 2008 | 12:18 AM
vetteracerx
Engine is fine. Could the propeller shaft be bent?
To Torque tube thump?
