FOB Programming
Old Dec 18, 2001 | 02:06 PM
computex13's Avatar
computex13
2nd Gear
Default FOB Programming
I can only program one fob. They both can be programmed as the first FOB, but when asked to hold "lock and unlock on 2nd FOB" nothing happens. Any advice?
Thanks,
Mark
Old Dec 18, 2001 | 02:12 PM
C5Cemo's Avatar
C5Cemo
Default Re: FOB Programming (computex13)
I got this info from C5-Tech:
PROGRAMMING TRANSMITTERS
Turn the ignition to ON.
Turn the radio to OFF.
Press the RESET button in order to clear any IPC warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the RESET button for 3 seconds.
Press the OPTIONS button until FOB TRAINING message is displayed.
Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
That should do it :cheers:
