pedal vibration
Old May 20, 2008 | 10:04 PM
tweakd's Avatar
tweakd
Default pedal vibration
Hey Guy's,
I know this is kind of a vague question, but I get this vibration in my gas pedal....to me it is all the time. I can also feel a little bit in the clutch pedal. It seems to get worse the higher the rpm, but it is all the time and is driving me crazy. Does anyone know what might cause this type of gas pedal vibration? Maybe a motor mount?
Old May 20, 2008 | 10:14 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by tweakd
Hey Guy's,
Make sure it's not speed related since speed goes up as the RPMs do. If it does it at idle with the car in neutral, you need to look at your flywheel and clutch assembly. Has there been any work done on the car recently? Ever replaced the clutch and flywheel? Does load affect it? In other words, if you stomp the gas or give it more throttle does it get worse? Things to check are rear tire balance, torque tube issues, clutch and flywheel, dampener coming apart, then maybe motor mounts. Bottom line is that the gas pedal is not even connected to anything on the motor. It only mounts to the firewall and electrically controls the throttle body. I'm sure the vibration is simply coming through the firewall or is possibly in the entire chassis. Try and gather more circumstances that make it appear and make it worse or better. Get to highway speed where it's doing it really badly and then push in the clutch and see what happens. Then rev the engine with the clutch in. Then let out the clutch and ease into the throttle and see if the load affects it.
Old May 20, 2008 | 10:30 PM
tweakd's Avatar
tweakd
The car is pretty stock. I just put new wheels/tires on it, brakes also, but it did this before i did any of this. To me it just seems like i can feel it more. I am not sure if it because i got rid of the old runflats or not. I am going to try diferent things like you said and see if i can narrow it down. It is hard to explain, but i just hate the way it feels under my foot. Thanks for youe input.
To pedal vibration
