OK guys I need your help. I bought a set of T-84's from a great member ljthe2nd just the other day. They were from PFYC and they came with the high wattage wiring and bulbs. What I would like to do is use a 6000 HID H4 XENON kit. Questions are can I use the wiring suppled with with the kit or buy a dedicated wiring kit that I have found on _ bay. I would like the set up to have both low/high beams. I'm sure that some of you have this setup already, how do you like it and what problems did run into that I need know about? Also if you have a how to with pictures that would be GREAT!!! TY
I have 6000k low beams and a halogen high beam. The high beam is useless.
I used the the same harness you already that came with the PFYC kit, its all plug and play, i have not had any prob. since i installed it over a year ago.
This looks like a really good thread.
I too have the T84's and am considering the HID conversion, I currently have 4350K bulbs.
They are OK on low beam but highs are pretty much worthless.
Or maybe going to the high wattage euro bulbs, has anyone done that?
I have been using a 130/100W Narva H4 bulb in my T84's. Throws out alot of usable light with the correct pattern.
