Fuel Tank problem
Old May 22, 2008 | 04:41 PM
RidgecrestC5's Avatar
RidgecrestC5
Default Fuel Tank problem
Yesterday I ran out of fuel on the I-15. I know I had fuel but my guage has been flacky lately so I was going by miles for fill up. Anyway once I got to gas station it only took 9 gallons of fuel. Guage works fine for about 100 miles then dropps to nothing but it seem as if the fuel is not getting from one tank to the other? Any ideas?
Old May 22, 2008 | 05:24 PM
jirasvet's Avatar
jirasvet
If you say it ran out of fuel and only took 9 gallons,Sounds like you are having problems with the RH Fuel tank with the siphon jet pump being clogged. Car would not run if the LH tank pump was not working.
Old May 22, 2008 | 05:34 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
If you were going by miles... how many miles did you drive before you ran out of gas?
Old May 22, 2008 | 09:29 PM
corvettejoe98's Avatar
corvettejoe98
sounds like you need about 4 bottles of techron. Use 2 for every 20 gallons. Let it sit over night each time and then just drive it. Use only top tier fuel too. (shell v-power) to be specific. Had a major gas guage problem and have been using techron and only shell v-power and its about 90% fixed at the moment.
Old May 23, 2008 | 02:21 AM
BlackZ06's Avatar
BlackZ06
Yup .... check the DTC data to confirm, but sure sounds like your car is not transferring fuel from the right to the left tank. The PCM recognized this and commanded the IPC to display LOW FUEL on the DIC and to set your fuel gauge to EMPTY. You ran out of gas because you decided to ignore the warning messages. You tried to "outsmart" the car ..... well guess what ... car is smarter than you.
Old May 23, 2008 | 09:04 AM
RidgecrestC5
Any Ideas how to unclog. I only run Chevron Premium and my Wife also knows to only use Chevron????
Old May 23, 2008 | 10:14 AM
BlackZ06's Avatar
BlackZ06
As I said in my above post .... check the DTC data to confirm ....
You could try some Techron, but if the right tank is not feeding fuel to the left, the Techron probably won't help. Also, with the right tank already full ... there is very little Techron that will get over to it.
You will need to pull the right tank sender and inspect the pump.
* Right tank pump is fed fuel from the pressurized fuel line out of the left tank/electric fuel pump. Ensure it is being supplied fuel for the "siphon" effect to work.
* Pump may be clogged with debris
* The feed line from the siphon pump to the left tank may be clogged.
You will need to plan on draining about 9 gallons of fuel from the right tank in order to remove the sender.
DO NOT work on the fuel system in a garage or other location that has any kind of ignition source such as a water heater. You will have an almost explosive mix of gasoline fumes .... certainly a highly flammable mix. Be careful.
Old May 23, 2008 | 02:07 PM
dredpyrt's Avatar
dredpyrt
Default Sender
Can the sender be accessed without dropping the fuel tanks?
Old May 23, 2008 | 02:15 PM
LoneStarFRC's Avatar
LoneStarFRC
Yes.
Old Jun 4, 2008 | 02:24 PM
RidgecrestC5
I took the Vette to dealer for repair, there was no codes in the DTC but the technician said since the Fuel gauge was registering empty it tells the left tank to quit pumping to the right so once the right is empty there you sit. New fuel sending unit fixed problem.
Old Jun 10, 2008 | 03:52 PM
MRRAZZY2003's Avatar
MRRAZZY2003
Default Fuel Gauge
to Corvettejoe98:
I've been trying the Techron in a 2004 with no luck. Been using Shell with it. I'm on my 4th bottle and only with Shell. Any tricks to be aware of? I can live with it, but what a pain. Mine quits at about 1/2 tank down to about 1/4. Fine on both sides of that range. I know my cruising range pretty well so have been managing it but one would thionk when we spend what we do on these cars, we'd get a fuel system that would work properly.
Old Aug 21, 2024 | 05:41 PM
ijakie1's Avatar
ijakie1
This has been an issue w/my low mileage 2000 c5 6-spd. question, when the "LOW FUEL" LIGHT goes on & thegauge goes to "E" I wait about 20-30 sec. & hit the "Reset button" & light goes away. Later on into the drive I Stop at a fuel center & clear & reset the codes, usually the pcm & bcm codes > everything is fine til about 80-100 miles later & the low fuel light does it's thing again. Is this procedure doing any harm? I've been a c4 tech guy for many yr's & never had this problem with fuel level sending units. I Love my c5, but everywhere i turn to find the passenger side (rt tank) fuel sending unit is not to be found. I would be very grateful for any leads to where i could purchase this item. Also just the othe day went to cruise to Shreveport, LA approx.110 miles one way to east of me, gauge & mileage was reading approx.209 miles to empty & ran out of fuel pulling into the prk'ng garage @ the Horseshoe Casino, NOT A HAPPY CAMPER.!! There should be a massive recall / service bullentin issued. One would say ur dreaming.
Old Aug 21, 2024 | 07:46 PM
USAZR1's Avatar
USAZR1
You think a 24yr old car should be issued a "massive recall"? Yes, you are dreaming, unfortunately.
Before trying to find a discontinued fuel sending unit, have you tried running Techron fuel system cleaner in the tank?
Old Aug 22, 2024 | 09:49 AM
ijakie1's Avatar
ijakie1
Before trying to find a discontinued fuel sending unit, have you tried running Techron fuel system cleaner? To answer this question, YES. I did not go into the detailed diagnostic procedure i've performed. I've removed the RT sending unit completely thru the access which on this model is a " PLUS" & I'am very thankful to the engineering for this access port. I did this at my local chevy dealer due to my relative is one of their Vette Mech. He wanted to see if the contacts & contact board was not damaged on this OLD 130K mile c5. We've did a pretty good search for this item. We found a shop in the pennsylvania area. I spoke with the mngr of this mostly Corvette Shop. He stated when they run into this fuel sender prob. they use theCadillac XLR-V, that graced our lives from 2006 to 2009. I asked who was the supplier they used but was NOT afforded an answer. My tech relative is still doing research. also at ROCK AUTO they list (2-3) supplier's but are "out of stock".Have u dealt w/ ROCK AUTO? I would be most grateful for a good source for this fix. BEST, G.E
Old Aug 22, 2024 | 10:40 AM
ijakie1's Avatar
ijakie1
question, were u using the 20 oz bottl's?
Old Aug 22, 2024 | 11:38 PM
USAZR1's Avatar
USAZR1
It would not surprise me if another vehicle used the same unit. C4 ZR-1's used primary and secondary fuel pumps that cost well over $1,000. 1999-earlier Suburbans with 454 engine used the same pump but cost on those was only $65.
Rock Auto is a top-notch supplier.
Old Aug 27, 2024 | 04:30 PM
2010Pony's Avatar
2010Pony
I’ve only used the 12 oz bottles and without any luck for the last 3 years. So what would be better 2 of the 12 oz (autozone) buy one get one or the 20 oz. This is a pain in the *** kinda thing.
Old Aug 27, 2024 | 05:33 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Are you asking if it's better to use 20 ounces instead of 24 or 20 instead of 12 or 24 instead of 12?
Obviously if you've been using 12 with no results for three years then using 12 isn't working.
Start with reading directions on the label and go from there. 24 is likely fine to use but it's doubtful you're going to get any better results. You seem like a patient and hopeful person so maybe trying 24 for a couple years would suit you. Cross your fingers the aftermarket has come up with a good solution by then.
Old Aug 27, 2024 | 06:45 PM
2010Pony's Avatar
2010Pony
Thanks that a lot of numbers 🤣 think I will buy 2 for 1 12 oz that would make 24 oz. Put 20 in the car and drink the other 4 that way we both get cleaned out.
To Fuel Tank problem
