C5 headlight problem
Old May 24, 2008 | 02:28 PM
leopoldml's Avatar
leopoldml
Cruising
Default C5 headlight problem
Headlights on my 98 stock vette do not turn off - nor do the headlights recess when the ignition is turned off. This just started happening without warning. Could be a bad switch, but looking for idea's before I begin shootin in the dark. Have to unlatch the headlight connections in order to get them off in the meantime. Thanks for your help.
Old May 25, 2008 | 02:27 AM
eylesda's Avatar
eylesda
When i first took my C5 home and put it in the garage I had the same problem. What a dope I was, the lights were set to automatic sensor i.e. turned themselves on in the dark. had to phone the previous owner
to solve the problem!
Maybe you have unintentionally switched settings.
Old May 25, 2008 | 02:31 AM
DeeGee's Avatar
DeeGee
First the obvious:
Make sure the battery is properly connected and tight.
Check relay #44 which controls the headlights.
Check fuse #6 in the passenger footwell which can affect the doors.
Disable Twilight Sentinel in the DIC so you're working just manual mode. It'll help troubleshoot.
If both doors are affected and they stay open I'd start at the headlamp door actuator module. Check the connectors to the actuator for damage and clean them up.
Recycle the headlight switch quite aggressively to see if you can get them to move at all. It could be a bad multi function switch (the one on the steering wheel stalk). If you get any movement at all, there's the snag. Try some electronics cleaner squirted into the switch. It may clean up the contacts. Failure of this switch is common and causes all sorts of problems.
Ultimately it could need any of those components changing but you need to track down the problem first.
Old May 25, 2008 | 02:32 AM
DeeGee's Avatar
DeeGee
They should still stow once the ignition is off even if twilight sentinel is on. There should be a delay when the key is pulled and then they should close. Mind you I did have one gremlin where I shut down with high beam and they wouldn't close until I selected low beam. I don't use TS by the way.
Old May 25, 2008 | 06:10 PM
leopoldml's Avatar
leopoldml
Cruising
Default Follow-up: Still Problem
Checked all fuses and relays - all look good. Battery connection checked and good. Plugged headlight harnesses back in - same problem - lights go on as soon as the harness is plugged in. Regarding twilight sential option, I went through DIC, and found no options for this. Also referenced manual, no mention. Not sure I even have this option. Although I am working in daylight,
so this shouldnt be causing it I would thinkg.
Played with the headlight control cluster stalk. When moving control slowly between OFF postion and PARK LIGHTS position, the lights turn off and the headlight motors engage and close. As soon as the the control is moved to either park or off, the Headlight motors open and lights return to on. The only way to turn the headlights off is to unconnect each of the headlight harnesses. Weird! Any other suggestions? I appreciate the help!
Old May 25, 2008 | 08:23 PM
lionelhutz's Avatar
lionelhutz
Well, your troubleshooting sure seems to indicate the switch is bad.
Peter
Old Jun 30, 2008 | 03:58 PM
sjfd20's Avatar
sjfd20
what links do I go to to purchase headlight/ blinker switch?
Old Jun 30, 2008 | 04:00 PM
sjfd20's Avatar
sjfd20
I have mine out and am going to take it apart and see if I can repair it, but if not will have to buy a new one and do not want to pay dealer prices if I can help it.
Old Jun 30, 2008 | 04:31 PM
DeeGee's Avatar
DeeGee
Headlight Switch Replacement
http://forums.corvetteforum.com/show...unction+switch
Old Sep 7, 2014 | 11:56 AM
dutch911's Avatar
dutch911
Headlight blinker switch has a problem with the spring failing. You can take it off and disassemble it and bend it back into place and it's work for another month or two--which I did three or four times before breaking down and buying a new one. Buy a new switch, it's worth it.
Old Apr 17, 2019 | 09:36 AM
bp308's Avatar
bp308
Default Headlight open and close
The driver side headlight on my 1991 Corvette will not open all the way. When I turn the headlights on I can give a gentle nudge and the light will open completely. There is no problem closing. Suggestion?
Old Mar 1, 2021 | 04:25 PM
Bpro2021's Avatar
Bpro2021
1st Gear
SEE FULL ARTICLE HERE
To C5 headlight problem
