water temp
Old May 24, 2008 | 07:02 PM
92banana's Avatar
92banana
Default water temp
Hi
This is my first summer with my 02 convertible. What are considered normal water temps in stop and go driving? Today I ran 194 cruising down the freeway on a 78 degree day and up to 225 in traffic. Is this normal? thanks. Randy
Old May 24, 2008 | 08:20 PM
vettenuts's Avatar
vettenuts
Yes, unfortunately stock fan setting don't come on until around 228 degrees. I have a Vinci fan switch in mine, they now come on at 207 degrees.
Old May 24, 2008 | 10:13 PM
65GGvert's Avatar
65GGvert
Not unusual, but check up between the radiator and condensor fins for debris, leaves, bags, etc. The cleaner it is the cooler it will run at speed.
Old May 24, 2008 | 10:22 PM
randy814u's Avatar
randy814u
Normal.
Old May 24, 2008 | 11:43 PM
92banana's Avatar
92banana
Default water temp
Thanks for the imput. I am used to cars running a constant temperature. I had guessed this behavior was normal judging by the fact that the fan comes on a such a high temperature but I wanted to ask the experts. thanks. Randy
To water temp
