Alternator pulley removal
Old May 24, 2008 | 10:31 PM
whitelite's Avatar
whitelite
Default Alternator pulley removal
Just got a new alt pulley and decided to use the power of the forum to get the easiest way to pull the old pulley off. Do you need a puller or will the OEM pulley come off with a little tender lovin' prying?
Thanks,
Randy
Old May 24, 2008 | 11:12 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I just removed the nut with an impact, heated it up with a propane torch and used a 2 claw puller with an impact to yank the old one off. The new one didn't fit that tight. It slipped right on.
Old May 25, 2008 | 04:34 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Depends on which pulley you have. If you have a clutch type alt you will need a special tool to pull the pulley.
Old May 25, 2008 | 05:27 PM
whitelite's Avatar
whitelite
Not the clutch type is part of the reason I'm replacing it. I keep having belts climb to the inside of the alt pulley. Checking alignment is harder than it seems....looks good to the naked eye.
Due to my mods I bought a Rev-Extreme billet pulley with higher sides to try and keep it from jumping.
Old May 26, 2008 | 12:07 AM
itzza427's Avatar
itzza427
Never heard of a clutch on alternator pulley (only A/C) is this something new??
Old May 26, 2008 | 11:28 AM
BLOWNBLUEZ06
I think the alternator with the clutch is on the 04's with automatic transmissions only. Something GM did to cure an issue.
Old May 26, 2008 | 02:56 PM
Mike Mercury's Avatar
Mike Mercury
It started (I believe) in 2000 or 2001. My 2002 A4 has the clutch pulley.
Old May 26, 2008 | 05:37 PM
itzza427's Avatar
itzza427
That's why I keep poking around the forum,,,Learn something new ALL THE TIME !!!Been working on/mess'en with cars and bikes for more than 45yrs,,but when it comes to SOME of the newer technology it can be a bit humbling!! Still a lot of the same basic nuts and bolt in there,but a lot of "WIZ BANG" new fangled tech in there. Have a grip on a fair amount of it,but there's ALWAYS a new curve ball here or there!! Keep the info coming!!
Old May 31, 2008 | 01:19 AM
CaliforniaJack's Avatar
CaliforniaJack
Default WHY is there a clutch on an alternator?????
O.K. Why do they need a clutch on an alternator??
To Alternator pulley removal
