Well which is it? I would think you would place the valve before the can in order for the can to catch anything that passed the valve. I have seen pictures however of the valve at the manifold after the can???
Also if you take note of these pictures, one picture has the nipple of the PCV going toward the manifold, and the other has the nipple going toward the valley...
The PCV valve requires oil-lubrication, so typically, a catch can device is plumbed downstream. However, given that most catch cans do not trap all the oil that is in aerosol form, it probably doesn't matter.
What you'll find is that on LS1s the PCV valve will be easiest to hookup before the CC. On the LS6s the PCV valve will be easiest to hoopup after the CC. This is just due to the way GM has set them up in the OEM configuration.
Most important thing is to make sure you get the direction of the PCV right. Later year LSx engines don't have a spring loaded PCV valvle, but simply a fixed 2.5 mm orifice to regulate the crankcase vapor flow through the PCV system.
I made sure to blow through it to ensure correct direction of air flow. I need to rig up a fresh air line to the valve cover as I don't think I'm going to run the vented oil cap....
I'm running the vented oil cap on both my C5 and C6 catch can setups with no issues. I got mine from www.RevXtreme.com . I believe some guys have complained about an oily mess underhood, but I'm not having this problem. By the way here is a picture of what my catch can caught after less than 1,000 miles on my H/C C5.
I've spoken to some people who have the same type of setup. They told me that the "mess" (oily residue on engine parts) happens after many thousands of miles. It might be a bit soon for you to see the buildup of oil in your engine bay.
