You will have to look year-by-year at the data .... Use the HOW TO ORDER fields to select a year/make/model (2005/Chevrolet/Corvette) and it will display all colors available that year including a "sample" of the color .....
Your monitor may display the sample as a slightly different color than the true color ... and the samples may not be perfect reproductions of the actual color ....
If you want to compare colors from different years side-by-side open a window for each year ....
