Waranty/master/slave
Old May 26, 2008 | 06:52 PM
bobdobb's Avatar
bobdobb
Default Waranty/master/slave
I have tried bleeding and bleeding. The peddle does not stick to the floor any more but run hard through 3 gears and the system makes little to no presure. Sometimes I can't even get into 4th for a full second or so. My question is has anyone ever been able get these parts covered by an aftermarket waranty without having fluid leakage. The dealer says that is only way they will cover it. OR is another method I can try to make it work better?
