oil leak
Old May 26, 2008 | 07:37 PM
dman00007's Avatar
dman00007
Default oil leak
Hey I have a 2002 coupe I had some modifiactions done. I had a new cam and new heads new intake. I also had a hi volume oil pump installed
besides other mods.
My problem is I have a oil leak on the passenger side of the engine. It only starts leaking at around 3000 RPM. It's in the lower part of the engine. The whole bottom half of the motor is covered in oil. I was wondering if anyone out there has had this problem. I'm thinking it might be the oil pan gasket but would it leak all the time even sitting still in the garage. I want to remind all of you it only leaks at high RPM 3000 OR MORE.
Dennis
Old May 26, 2008 | 08:23 PM
VinnyT's Avatar
VinnyT
Sounds like too much pressure from the oil pump. Any idea what psi the oil pump is pushing?
Old May 26, 2008 | 08:57 PM
vettenuts's Avatar
vettenuts
I doubt its the pan, the oil is probably leaking elsewhere and ending up on the pan. For cam and heads, I would suspect the front seal or possibly the timing cover. Like VinnyT asked, what is your pressure? You may also be pushing too much to the top of the motor. My first suspicion would be front seal though, look under the car near the crankshaft pulley, see if the area is wet.
Old May 27, 2008 | 06:28 AM
dman00007's Avatar
dman00007
Default oil leak
Vinny
I have looked at the front seal and timing cover gasket and it's bone dry.
The oil pressure if I remember correctly at 3000 rpm is around 45 to 50 psi. I will have to pay attention to this the next time I start the car. I never gave it a thought to be honest.
The leak seems to be towards the bottom end on the passenger side
towards the back of motor.
This has me stumped I looked to see if there is a sensor on that side of engine. I didn't see one on this side.
Hey once I get this problem fixed doe anyone including yourself have a sugesstion what to use to clean this oil off my under side. My stainless steel long tube headers have taken a beating and my hi flow cats. including my s/s magniflow exhaust. I have oil alll over the underside.
Dennis
Old May 27, 2008 | 07:34 AM
vettenuts's Avatar
vettenuts
Two other suggestions. I believe the oil level sensor is in this location, is that dry? Also, sometimes the oil pressure sensor will leak and run down the motor along the back.
Old May 27, 2008 | 08:23 AM
Pro Street's Avatar
Pro Street
Check the dip stick tube.
Old May 27, 2008 | 11:39 AM
dman00007's Avatar
dman00007
Default oil leak
Thanks for the suggestions I will check both. I new I can count on my friends form the forum.
Dennis
Old May 27, 2008 | 06:13 PM
J.R.'s Avatar
J.R.
I agree with Pro Street.
Sounds like dipstick tube. If it is, a new seal on dipstick should solve problem.
Old May 28, 2008 | 07:37 AM
timemender's Avatar
timemender
Dennis
You can run it up on my lift if it would help. Check your PM inbox.
Jim (timemender)
Old Jun 1, 2008 | 07:26 PM
Pro Street's Avatar
Pro Street
Well what did you find?
Old Jun 2, 2008 | 01:24 PM
dman00007's Avatar
dman00007
I want to update all of you on my oil leak it was the o ring on my dip stick. I can't believe the mess I have to clean up under neath from this little o ring. Hey any sugesstions as to a good solent that would especially clean my Stainless long tube headers they are a mess. My floor boards got a good oiling bath also and needless to say the tranny and the rest of the under carriage.
Once again I can always count on my friend here at the forum for help.
Dennis
Old Jun 22, 2008 | 08:39 AM
B-Vette's Avatar
B-Vette
Currently watching my own oil problem.
Old Jun 22, 2008 | 12:28 PM
FL_Dave's Avatar
FL_Dave
Default Brake Clean Fluid
I've had very good luck cleaning oil from engines & tranny's using brake cleaning fluid with a straw extender. It sprays on precisely and drips to the newspaper pile underneath -- no wiping required.
This technique is especially useful when trying to ID a new leak. Once the area is cleaned, a short test drive will show the origin of the oil.
Dave
Old Jun 22, 2008 | 02:28 PM
LoneStarFRC's Avatar
LoneStarFRC
A large spray bottle of Simple Green works well and is easy to hose off after without damaging anything. Just don't let it sit too long before you remove.
HTH
Old Jun 22, 2008 | 11:20 PM
B-Vette's Avatar
B-Vette
GM's engine shampoo works well too.
Old Jun 23, 2008 | 01:03 PM
peebee_c5's Avatar
peebee_c5
Maybe a citrus degreaser.
Old Jun 23, 2008 | 01:37 PM
jedblanks's Avatar
jedblanks
HTH
Old Jun 24, 2008 | 10:04 AM
jovette's Avatar
jovette
HTH
Be careful using the simple green on aluminum..........good advice about not letting it set too long............personally, I'd go the spray brake clean route with lots of old newspapers on the floor below, to catch the mess. I've used brake clean with success to clean fender well areas as well, once wheels are removed........spray liberally, and then use old throw away rags to wipe clean. Repeat process if necessary to remove excess road tar etc.
Old Jun 24, 2008 | 12:23 PM
LoneStarFRC
One thing I like about Simple Green and some of the citrus-based products is that they are non-toxic and biodegradable.
To oil leak
