Anyone know what would cause wheel hop on my 99 Corvette(6sp,ac/tc,z51)? I am running stock rubber and the suspension hasn't been lowered. Any suggestions on how to cure this?
Phillip :rolleyes:
My 79 never had wheel hop, nor did my 94 or 96 ever ever wheel hop, laying rubber was a blast in those cars. The 1st time I dumped the clutch in my C5 I almost cried. GM has done a bad thing in the C5, I wont ever foregive them. Wheel hop in the C5 is terrible and very upsetting to me. IRS suspension? show me a post on the C3 or C4 board with a wheel hop complaint. You may dig one up but I never ever experienced it in any Corvette except the C5.
It was wheel hop that brought me to search out a Corvette website back in 1999 when I found this site, guess what my 1st post was about :mad
Try feathering the clutch just slightly instead of dropping it hard. I find this eliminates the wheel hop most of the time, even when the tires are spinning hard. Don't feather too much though, as the clutch does not like too much slip. Yeah, it's a weakness of the C5.
This method has worked for me when launching as well but there is no permanent cure. When I got my Nittos I got more axle hop on the 1st-2nd shift because they have more grip and sidewall deflection. This problem will break driveline parts...I know :yesnod:
Here's my most recent experience. I took off slowly from a light in 1st gear. I took the rpm's up to 2500 and then floored it. Guess what, the tires broke loose and started hopping on me! :mad
BTW, it was a cold morning below 32 degrees because I never broke them loose during the summer doing the same thing.
This has been a topic on the Forum over the years. I've heard that lowering tire pressure can help. The stock EMT's are definitely not a good traction tire. I usually have a wheel hop problem going from a slow roll, and clutching it around 2000 rpm. Feathering the clutch is good advice.
I think you are missing the idea behind the C5, it is built to handle in the best possible way. The old generations of corvettes or any other car mentioned in this thread handle like the C5, not even close !
The suspension in the C5 is not optimal for hard launches as at a dragstrip. To gain it's handling capabilities we have to sacrifie something, in this case we get wheel-hop.
I've had coilovers from when my car was new, I've tried different tires and tire-pressures but I get wheel-hop at one out of ten launches. There are other tricks you can use to get rid of wheel-hop as mentioned earlier in this thread but none of them guarantees you to completely get rid of wheel-hop.
I'm not a suspension specialist but I've found that the C5 do not get any weight transfer to the rear as in other cars with old-fashioned suspension technology. My cure was to use adjustable shocks making the front very soft when dragracing getting much weight transfer to the rear. No more wheel- hop ! I've been reading about forum members that disconnect the front shocks completely when dragracing(cheap adjustable shocks :) ).
My primary use of the car is roadracing which I think the C5 is built for.
Please no flames. This is only my personal opinion.
:seeya
No real fix unless you get a solid rear axles. You can control it by feathering the clutch, but you'll probaby significantly shorten the life of the clutch. I just try to feather the gas pedal. My times will never be as good as they should be, but at least my clutch will last a bit longer.
For those of you saying there is no solution to the problem, it's no wonder you still have it. It has nothing to do with IRS, it's a lack of shock valving control. It can be dialed out with a properly valved set of adjustable shocks. We discussed it in great detail recently: http://forums.corvetteforum.com/zerothread?id=188162
By the way, I agree that is has little to do with IRS. Back in the muscle car days, several cars went to staggered shocks to get rid of axle hop (one shock in front of the axle, the other side on back of the axle).
The cure for wheel-hop is adjustable shocks such as Ohlins shocks. To the left my front Ohlins coilovers, to the right my old non-adjustable front bilstein coilovers.
Several of the supporting vendors have adjustable shocks to offer. The most common adjustable shocks (at least when reading posts on this forum) seems to be HAL's, they are optimized towards dragracing. If your major use is roadracing go with Ohlins or Penskes.
