what bolts will lower a c5 more?
Old May 27, 2008 | 12:50 PM
02gt350's Avatar
02gt350
Default what bolts will lower a c5 more?
will c6 bolts lower more?
Old May 27, 2008 | 02:19 PM
black98c5's Avatar
black98c5
This is the kit I used http://www.zip-products.com/Zip/prod...71391FF394D459 The car is slammed. I heard of people just buying the bolts from Home Depot and getting the bolts for a bit cheaper but I didn't feel like messing with all that.
Old May 27, 2008 | 03:14 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I put this together a few weeks ago... Pics of stock height, then lowered max on stock bolts, then lowerd max with the front C6 bolts, and longer rear bolts.
Below pic....Lowered max in the front with C6 bolts, and adjusted the rear longer bolts to where it looked right in line with the front height.
Old Jun 8, 2008 | 08:02 PM
KWIKSS's Avatar
KWIKSS
So you bought C6 front bolts and what do you mean by longer rear bolts. The stock ones, or did you buy some. Thanks
Old Jun 8, 2008 | 08:03 PM
jdmvette's Avatar
jdmvette
Night Owl for life
longer ones.
Old Jun 8, 2008 | 09:25 PM
Tom Porter's Avatar
Tom Porter
I removed the front bolts and installed 8" x 9/16" Grade #8 bolts. The stock rear bolts are around a 1/2" dia and 6" in length. The rear bolts are quite a bit stronger. You can see my avatar and see how much it is lowered. It's stance is the same as the silver Z06 in the earlier replies.
Old Jun 8, 2008 | 11:51 PM
Ryan L's Avatar
Ryan L
C6 fronts will drop the front about .25" more than the stock bolts. Removing the bolt completely will give you another .25" or so.
Old Jun 9, 2008 | 10:23 AM
Toque's Avatar
Toque
http://www.westcoastcorvette.com/p-1...-bolt-kit.aspx
http://www.westcoastcorvette.com/p-3...-bolt-kit.aspx
That should get it done for you.
Toque
To what bolts will lower a c5 more?
