Alternator OR BATTERY
Old Jun 8, 2008 | 07:19 PM
sixgears1@aol.com's Avatar
sixgears1@aol.com
Default Alternator OR BATTERY
I have 98 c5 the volts read 13.1 to 13.4 on the highway when i am in the city and its hot it drops to 12.2 to 12.6 is the alt going bad or is the battery getting weak dont wont to get caught on a trip and alt goes out.
Old Jun 8, 2008 | 11:13 PM
bestvettever's Avatar
bestvettever
Default Could be bad alt or bad battery
Hi, How many miles on the car/alt, how old is the battery, what is your driving pattern,(dd or occaisional). The readings you are getting do seem low. When things heat up under the hood the regulator cuts back on alt output, hence the lower city when hot readings. You could have one or a few different problems.
1, It may be as simple as a battery going bad, highly sulphated and not able to take a full charge , which fools the system to cut back on output.
2, The cables may be loose or dirty.
3, The regulator may be going bad.
4, The alternator could be going bad.
If the battery is more than a few years old I would look there first, after I verified that all the cables were clean and tight,(both sides at the battery, starter, and fuse block, also the connections going to the alternator.
You can load test the battery to confirm that it is in fact fully chargeable.
Then field test the alternator to see if it is able to output at least 15 volts.
Good Luck
Old Jun 8, 2008 | 11:44 PM
oakvillec5's Avatar
oakvillec5
also 14 or higher all the time...good luck with an inexpensive fix !
Old Jun 9, 2008 | 07:23 AM
sixgears1@aol.com
Default Alt
Car is a weekend driver battery is 3 years old always keep battery tender on it when put up will check that first probaly will trade it out to see .
Old Jun 9, 2008 | 09:42 AM
wildbadbill's Avatar
wildbadbill
Are your readings from the DIC or actual on the battery posts?
Old Jun 9, 2008 | 11:24 AM
sixgears1@aol.com
Default Alt
From the dash
Old Jun 9, 2008 | 11:29 AM
wildbadbill
From the dash
you may have the same issue as me-the number on the dash is about 0.6V lower than the actual on the battery.That would indicate bad connection between the battery post (positive) and the inside fuse box from which the dash is supplied.I'll have more info tonight...
To Alternator OR BATTERY
