Changing Plugs
Old Jun 1, 2008 | 10:45 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Taxman and Millenium -
Its all good.
I assume you are saying remove the coil packs on the left (drivers) side of the engine - and that is easy enough - if it works, awesome!!
I chose to remove the two AIR tube bolts on that side, and I was able to get my fat hands in there with plug-boot pulling pliers and pull the heat shield and boot off with no problems.
Additionally, I used a curved-handle, flex-head ratchet wrench that I bought for $8 at Harbor Freight to ease the job of getting the plugs broken free. Once they are broken free, you can use your hands to unscrew them (usually...)
best regards -
mqqn
Old Jun 1, 2008 | 10:52 AM
02MillenniumVette's Avatar
02MillenniumVette
Its all good.
best regards -
mqqn
Old Jun 1, 2008 | 04:16 PM
itzza427's Avatar
itzza427
Its all good.
best regards -
mqqn
Wrestled around with taking all the air tube hoses off the drivers side. mggn posted his DIY in my thread about the 100,000 myth!! I am DEFIANTLY keeping the tube removal in my mental arkive for the next time.Moving the hoses helped,,but moving the whole system is even better. to mggn I need to learn how to link as I like to forward Mggn's DIY!!
Old Jun 1, 2008 | 07:22 PM
thetaxman's Avatar
thetaxman
Its all good.
mqqn
but I've never had to do either
maybe it's because I don't even try to use my hands to pull or replace the plug
