Changing Plugs
May 28, 2008 | 10:47 PM
Changing Plugs
On the 99 C5 is is it easier to change the back spark plugs from the top or the bottom, on either side of the car?
May 28, 2008 | 10:53 PM
May 28, 2008 | 11:31 PM
Quote:
Originally Posted by
itzza427
I just did mine 2 weeks ago, took all of 45 minutes.
Don't forget to use anti sieze on the plugs & dielectric grease on the plug boots.
May 29, 2008 | 08:22 AM
Changing Plugs
Thanks for the advise. I think that it'll make the job much easier. I'm going to guess maybe an hour or so.
May 29, 2008 | 08:53 AM
You can do it from the top and I found its a lot easier to do if you take off the coil packs.
May 29, 2008 | 11:19 AM
Is it a good idea to change the plug wires at the same time? Are the wires usually fine or usually should be replaced at about 50,000 miles or any milage? Any ideas on how to check them out?
May 29, 2008 | 11:35 AM
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi folks -
How to change the plugs and plug wires -
best viewed with Internet Explorer....
http://www.iammoon.com/c5tech/c5_plugs.htm
I changed the plug wires on my wifes 99 coupe when I did the plugs - almost 10 years old and they would be off anyway, so why not - plus I went with the red GM "performance" wires....
best regards -
mqqn
May 29, 2008 | 05:09 PM
Yep,
GM Parts House has the red wire on sale for $55.20, scroll down a few posts and check out the sale.
May 29, 2008 | 09:27 PM
02MillenniumVette
you are joking right ?
May 30, 2008 | 08:33 AM
Cruise-In VI Veteran
One picture (Figure #5) shows the plug wire being pulled off by pulling on the heat shield. Is that OK to do?
May 30, 2008 | 08:38 AM
Cruise-In V Veteran
Benpup
Hi Jim -
Yes - that is the way to do it!
Here is the picture you are speaking about -
best regards -
mqqn
May 30, 2008 | 09:27 AM
thetaxman
Why would I be joking? Its a lot easier to get to the #7 plug if you remove the coil packs. Its not that hard, there are like 5 10mm bolts holding it on.
May 30, 2008 | 11:55 AM
02MillenniumVette
I can't imagine pulling the coils for that
I just use a swivel plug socket
easy as pie
May 30, 2008 | 02:16 PM
mqqn
Hi Jim -
best regards -
mqqn
Appreciate it. I took one off using the plug wire itself and it took forever so I put it off for another day. Should go easier now.
Thanks again.
Jim
May 30, 2008 | 02:23 PM
im going to attempt this when i get my red wires and plugs on monday
May 30, 2008 | 03:40 PM
thetaxman
easy as pie
Apparently I have bigger hands than you then cause I cant even get a swivel to it.
May 30, 2008 | 05:16 PM
02MillenniumVette
bigger hands....
I use an extension, my hands get nowhere near the plugs
May 31, 2008 | 11:02 AM
thetaxman
bigger hands....
Ive tried that too, doesnt work.
May 31, 2008 | 01:51 PM
02MillenniumVette
I've been doing it for
years
it does work
Jun 1, 2008 | 08:03 AM
thetaxman
I've been doing it for years
it does work
Good for you.
You obviously know something I dont.
