Tire pressure message
Old May 29, 2008 | 02:54 PM
chewyD's Avatar
chewyD
Default Tire pressure message
DIC it tells me service my tire pressure sensor system does anybody know if you can disconnect that message
Old May 29, 2008 | 03:20 PM
JOEY P's Avatar
JOEY P
The only way to get rid of the message is to pull the fuse if your running regular tires.
Without sensors.
Old May 29, 2008 | 03:24 PM
c5rulz's Avatar
c5rulz
If you have the original tire pressure sensors, the battery is probably shot in one of them.
Old May 29, 2008 | 06:42 PM
jrose7004's Avatar
jrose7004
Press reset and you'll find out which sensor is dead. The dead one will read XXX.
Old May 29, 2008 | 11:29 PM
coldvette's Avatar
coldvette
I have the same message showing on my '99. Did the reset thing several times, and it changes from LR XXX TO RR XXX . Depending how it feels.
If it is the batteries, how difficult to change and whats the model # ?
thanks anyone
Old May 30, 2008 | 06:32 AM
dixonk's Avatar
dixonk
St. Jude Donor '09
This just happened to me on the way home from work today!!!
Old May 30, 2008 | 08:06 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Old May 30, 2008 | 10:20 AM
Oldvetter's Avatar
Oldvetter
The TPMS can only be turned off in 2001 and newer C5s (when the Z06 came out without the TPMS).
The series I TPSs cost $91 each from Forum Vendors (Gene or Frictner's). You can switch entire system cheaper (2 fobs, 4 TPSs, and reciever) from Ebay.
Series I sensors are good for 7 years and 100,000 miles, so you are due if these are original.
Old May 30, 2008 | 05:48 PM
JOEY P's Avatar
JOEY P
He needs to say what he is trying to acomplish, Is it that he has no tire pressure sensors, Or is it that the ones that he has are causeing this message.....I myself have none on the car and I get this message....Thats why you pull the fuse....
To Tire pressure message
