Erratic fuel gauge
Old May 29, 2008 | 11:02 PM
wildbadbill's Avatar
wildbadbill
Default Erratic fuel gauge
I put some techron few times,but my gauge still acts up!
Even with the 1/4 of the tank it shows at times3/4 and so on.Is it connected to any grounds so it can give false readings?
thanks.
Old May 29, 2008 | 11:11 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
It sounds like it may be the passenger side that is having problems. There are fuel level sensors in both tanks. The way the system works, the passenger side tank is completely drained before starting on the drivers side. So, when the the passenger side is half full, the gauge shows 3/4, when it is empty, it shows 1/2 on the gauge, etc. The highest reading you can have with the drivers side tank would be 1/2 full on the gauge (drivers side completely full).
If you actually have 1/4 tank and it is fluctuating up to 3/4, it sounds like it may be getting an erratic reading from the passenger tank for some reason.
Old May 29, 2008 | 11:34 PM
wildbadbill
thanks,got it...I'll just keep adding techtron...lol
btw-like your avatar
To Erratic fuel gauge
