My coupe will leak what i think is water at the end of the header collector where it connects to the exhaust, is there any lines along that tunnel for the a/c?
here is a picture when my exhaust had come apart, it has been fixed, along the edge near the passenger side of the tunnel it is where water will drip a not so big puddle of water. hope you guys can understand what i am trying to say, any help would be great thank.
That would be your A/C evap drain dripping on your header and then to the ground. It's normal. Headers leaking is NOT. If you can get under the car and look on the firewall above your header you will see the little black 90 degree rubber hose. That's your evap drain. As long as it's draining your okay. If it ever stops dripping, your pass floorboard and your BCM are probably getting wet.
