TFS 215 guys inside
Old May 30, 2008 | 12:14 AM
ebz06dude's Avatar
ebz06dude
Default TFS 215 guys inside
what length pushrods are you guys running with your setup and how loud is your valvetrain with what rocker setup?
EBZ06Dude
Old May 30, 2008 | 08:58 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
EBZ06Dude
you should be in 7.700 range with 1.7 Harland Sharps
Old May 30, 2008 | 11:11 AM
ebz06dude's Avatar
ebz06dude
what about with yella terras? would this change?
Old May 30, 2008 | 11:31 AM
vettenuts's Avatar
vettenuts
Shim the Yella Terra's for wipe, then measure for pushrod length. Those lengths are pretty long and the pushrod stiffness decreases with length (about 15% for 7.700 from stock length), you might want to consider bigger diameter pushrods as well.
Old May 30, 2008 | 01:39 PM
ebz06dude's Avatar
ebz06dude
well my buddy ordered a vrx5 and tfs 215s and did 7.500 but i see everyone on here with different lengths i was trying to figure out what i need to order
Old May 30, 2008 | 02:01 PM
vettenuts's Avatar
vettenuts
Always order pushrods last. Install the heads, check the wipe on the rocker and shim accordingly, then measure for the pushrods. I measure for pushrods then continue the installation of parts, usually by the time you are ready for the pushrods they will be there. This time I am going with the Manton 11/32" OD pushrods. I had Terry make me one sample for mock-up and it is heads and shoulders better than the off the shelf and he will custom make the length.
To TFS 215 guys inside
