Z06 Vert Help !!!!!!! ???????
Old May 31, 2008 | 10:01 AM
vettvipper's Avatar
vettvipper
Default Z06 Vert Help !!!!!!! ???????
HEY GUYS I KNEED SOME HELP !!!!! I AM REBUILDING A 02 VERT WITH AN AUTO TRANY AND WANT TO PUT A 02 Z06 MOTOR IN IT . I HAVE BEEN TOLD THAT YOU CAN NOT JUST CHANGE THE MOTOR , I WAS TOLD THAT THE TORQUE TUBE IS DIFFERENT , IN THAT THE SHAFT IS BIGGER AND THAT MEANS YOU MIGHT HAVE TO CHANGE THE TRANNY TOO , HAS ANYBODY RUN INTO THIS BEFORE ????? I WOULD APPERACIATE SOME HELP THANKS
THANKS TOM H
Old May 31, 2008 | 10:23 AM
vettvipper's Avatar
vettvipper
BUMP
Old May 31, 2008 | 10:45 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
If you're using the A4 transmission and torque tube,the LS6 engine should bolt right up.
Old May 31, 2008 | 11:43 AM
vettvipper's Avatar
vettvipper
Default Zo6 Motor Swap
I Am Using The Stock Torque Tube And Tranny
Old May 31, 2008 | 12:48 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
should swap no problem.
Old May 31, 2008 | 01:19 PM
vettvipper's Avatar
vettvipper
THANKS BUMP
Old May 31, 2008 | 01:56 PM
Quicksilver Vert 01
Do you have the 3.42 rear from the Z06?
Now would be the perfect time to mate it with your LS6 engine swap.
Also,if you haven't spent your last dime yet,
Mike Mercury found a real sweet GM torque converter with a slightly higher stall speed than stock.He posted an interesting thread,which included the GM part number,after his installation.
Old May 31, 2008 | 02:51 PM
vettvipper's Avatar
vettvipper
Default Z06 Swap
DOES ANYONE NO IF THE FRC HAVE THE SAME REAR GEAR 3.42'S
THANKS
Old May 31, 2008 | 03:39 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
THANKS
Same.
Old May 31, 2008 | 03:44 PM
Quicksilver Vert 01
Originally Posted by XKR100
Same.
Any C5 with a manual transmission came with a 3.42 rear ratio.
Old May 31, 2008 | 08:37 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
THANKS TOM H
First off, all Z06's came with a manual torque tube, not an automatic torque tube.
The torque tube for an auto is different than that of a manual tranny.
You can use your existing auto torque tube for the conversion, it's no big deal.
To Z06 Vert Help !!!!!!! ???????
