Has anyone NOT had the fuel sender problem?
Old Dec 20, 2001 | 11:20 AM
Schwa72's Avatar
Schwa72
Default Has anyone NOT had the fuel sender problem?
I've read so many posts about erratic fuel gauge problems that I'm convinced it's a virtual certainty that I'm going to run into this issue with my '01 coupe. Has anyone not had fuel gauge problems after owning their Vette for a while?
Old Dec 20, 2001 | 11:24 AM
6699's Avatar
6699
Default Re: Has anyone NOT had the fuel sender problem? (Schwa72)
No problem so far!!!!!
Mikael
Old Dec 20, 2001 | 11:38 AM
RonWhite's Avatar
RonWhite
Default Re: Has anyone NOT had the fuel sender problem? (6699)
I think I may have had the problem this morning. I had a bit less than a 1/4 of a tank last night and this morning the low fuel light went on and the gauge was in the red. I was able to make it to the gas station and AFTER filling it the reserve fuel message appeared. The gauge remained on empty until I pulled into my spot at work. It went to full but still gave me a low fuel message. Not sure if this is normal for a low tank :confused:
Old Dec 20, 2001 | 11:40 AM
CHJ In Virginia's Avatar
CHJ In Virginia
Had my 2001 for 18 months and 17 K miles without a problem. You see all the problems on the forum, but never hear about the thousands of cars without problems. Don't worry and enjoy !!
Old Dec 20, 2001 | 11:43 AM
bob98's Avatar
bob98
Mine just started on my 98 with 49K. I have an appointment to take it in next week.
C5XTASY's Avatar
C5XTASY
13,000 miles on my 2000 and no fuel sender problems.:)
Ed
Old Dec 20, 2001 | 11:52 AM
GR8-LIFE's Avatar
GR8-LIFE
I'm not sure if I'm having a problem or not. My guage does tend to fluxuate about an 1/8 of a tank back and forth sometimes. But its never suddenly gone to empty. I have a little over 8K miles so far.
As far as a previous post suggesting you shouldn't be concerned, I would respectfully disagree. Anything that has a TSB out on it you have every right to be a little concerned.
Old Dec 20, 2001 | 01:21 PM
whip383's Avatar
whip383
Default Re: Has anyone NOT had the fuel sender problem? (bob98)
Bob, mine just hit a little over 49k, and it did it to me last weekend. Let me know what happens, costs, etc.. I do have gmpp.
Chan :cheers:
Old Dec 20, 2001 | 01:24 PM
Tracy's Avatar
Tracy
Default Re: Has anyone NOT had the fuel sender problem? (whip383)
20K miles on my 2000, born on Nov 12, 1999, no problem with fuel sender.
Old Dec 20, 2001 | 01:25 PM
Fahtrim's Avatar
Fahtrim
Default Re: Has anyone NOT had the fuel sender problem? (tracy)
No problem here.
Old Dec 20, 2001 | 01:29 PM
CABNETMAN's Avatar
CABNETMAN
No problems here either.
Old Dec 20, 2001 | 02:04 PM
XTrooper's Avatar
XTrooper
19K on my 2000 and so far, so good! :cool:
Old Dec 20, 2001 | 02:17 PM
ace's Avatar
ace
Default Re: Has anyone NOT had the fuel sender problem? (XTrooper)
Knock on wood........25k on my '99 and no probs.
Old Dec 20, 2001 | 02:20 PM
NJVetteGuy's Avatar
NJVetteGuy
That's probably the only thing I haven't had trouble with yet....Give it another few weeks and I'm sure mine will have that problem or another one.
Old Dec 20, 2001 | 03:06 PM
SilverStar's Avatar
SilverStar
Default Re: Has anyone NOT had the fuel sender problem? (NJVetteGuy)
By "fuel sender" are you refering to the fuel transfer pump. I just got bit by this one. Stalled on the freeway during morning commute. Gauge said 1/4 tank but one of the split tanks eas empty. Had to get a flatbed to the dealer. PITA. Took a week+ to replace.
Old Dec 20, 2001 | 03:21 PM
RajunCajun2001's Avatar
RajunCajun2001
None so far. :yesnod:
Old Dec 20, 2001 | 04:17 PM
chadwick's Avatar
chadwick
Schwa72,
When I bought my C5, I found statistics (carpoint/edmunds/CU) that said this problem was the #1 C5 failure, but still only affected about 16% of the vehicles.
Seems like something they should ahve figured out already. Go figure. :)
To Has anyone NOT had the fuel sender problem?
Old Dec 20, 2001 | 05:18 PM
TestAmenTC5's Avatar
TestAmenTC5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
My 2000 hasn't, but my wife's '98 has. I quit topping it off, and it quit being crazy. :)
Old Dec 20, 2001 | 05:47 PM
crocker's Avatar
crocker
No problem so far! 11,000 miles
Old Dec 20, 2001 | 08:28 PM
Jerryk's Avatar
Jerryk
Yes I have the fuel gauge problem, fill up and about 40 or so miles of driving the gauge drops to zero, the low fuel message comes on, check gauges light comes on. sometimes it comes back to normal in 20 min or so, normally if the car sits like when im at work everything returns to normal when i head home. Not sure what the cause could be dont see how topping off would cause it.
1998 C-5 A-4 jerryk :yesnod:
