I am having issues with the car running at low rpms. It only does it sometimes. When I start off in 1st or 2nd in low rpms from 1500k to 2500k it seems like the car falls flat on its face then when I give it alot of gas it seems to resist for a second then take off. It does it through all gears at low rpms. I dont know if it needs a re-tune or what. The car is a cam only car. It only started doing this when I had a new clutch installed.
Have not ever changed the fuel filter. Is there a write up on how to do that. Also it does not seem like its grabbing harder its more of a lag in the throttle.
There are many good tuners in the Houston area. PM me if you want the number to a few. There are a handful of things in the tune that could cause this problem.
Cars already got a good tune on it. But since i have added a few mods then it might need a retune. The only things added since last tune where Vararam Intake/Clutch
